How to clean aluminum intake?
1 Post
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I have a perf rpm air gap. The intake is new but I've gotten some rusted water and other stains on the aluminum. Besides carb cleaner, how can I clean the intake so it stays looking new?
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: How to clean aluminum intake?
edelbrock recomends a product called oxisolve
im gonna need to clean mine soon to i spilled coolant down in the lower pan section
I've had good luck using simple green to get the oil and grease off. Next I rub in mothers metal polish with a scotch bright pad then remove it with a cotton cloth. I've also used never dull too, it works decent too but I think the mothers polish works the best. Its time consuming but I've been able to keep my intake looking good after many years of use.
ambainb
04-25-2016 09:21 PM
mdtoren
08-16-2015 05:45 PM
