coat of mequiars cleaner wax?
Car: 1987 Z28 with iroc-z Package no.3
Engine: 350TPI
Axle/Gears: 3.73 posi
well tommrow im gonna use meguiars no#7 show car glaze. followed buy a coat of yellow carnuba wax. last weekend i clay bar,d the car followed buy a coat of cleaner wax. my question is do i have to strip that wax off. or can i get away with california car dusting then going about glazing. the car has seen 3 miles since the clay bar,ing and has sat in the garage since.
Car: 1992 Camaro RS
Engine: 3.1L
Re: coat of mequiars cleaner wax?
No, you don't need to strip the wax first but you may get better results if you do. A very quick once over with the clay bar again will strip the wax with very little effort - it's faster and easier than using a paint cleaner or a Dawn wash. I just did this to one of my cars a couple of weeks ago. I would suggest you go lightly with the Cali Duster and follow up with a quick detail spray to clean ALL the dust off before doing the clay again.
When applying the #7 make sure to work in areas no bigger than about 2' x 2', work it against the paint and wipe it off while still wet. Follow that immediately with your coat of, I assume, #26 Hi-Tech Yellow Wax. Put that #26 on nice and thin and let it dry for about 20 minutes before wiping it off. Put a second thin coat on just to ensure even coverage and appearance.
For what it's worth, I'm a Surface Care Specialist at Meguiar's in Irvine, CA. Just so you know I'm not making this up as I go along.
