My "budget" paint job.
#101
Car: 1988 Trans Am GTA
Engine: 5.7 TPI
Re: My "budget" paint job.
I am sure if you sanded down to metal for bondo then some primer won't hurt. I sanded down to metal in spots where the original paint was pealing and feathered the area and primed then painted the whole car. I found the quarts of Rustoleum in the paint section next to the spray paints. I used Rustoleum primer as well to keep the same brand as same brands tend to do better together. I haven't read or seen any duplicolor info.
Hope this helps....
Hope this helps....
#102
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
I haven't painted color yet but I am using the Rustoleum brown rusty primer over bondo. Put it on with a foam roller and wait an hour or so for it to dry. Wet sand 220 grit over a paint stick to find the low spots and repeat. It builds real quick and drys super hard.
Priming the whole car is a waste of time but you want to wet sand every square inch
The paint is located on top of the spray can shelf at my WalMart.
#103
Transmission: Automatic
I don't know about you guys but there is a close family friend that has all the tools and space to do it. I'm throwing him $100 to tech and help re-do the paint with me. I also have picked out a kit for the paint, clear, and primer for only $175 including shipping! So that's only $275 for a professional looking paint job. But if I hadn't found this "pro" connection of mine I would have went with this method. Very nice!
#105
I've been planning on doing this method for a few months now, what got me interested (besides the crazy automotive paint prices in CA) was reading a few articles on painting with Rustoleum. One article was a guy that painted his Falcon with it, another was the Charger article I think those used a foam roller, with the rollers you have to roll it on thin and put about 12 coats for good coverage. I've painted on and off since I was a kid (laquers, enamels, acrylic enamels, imron, etc.) so this will be a little different but pretty much similar to acrylic enamel and I hear you can use hardeners also. It's probably best to wait a few weeks before wet sanding and buffing. Acetone can also be used as thinner and make sure it is the oil based Rustoleum. I hear bird droppings if left on for weeks can eat thru which is typical of enamel. Tremclad from Canada seems to be a very similar paint as Rustoleum. Since I'm going to try to match color on my car I experimented and found out 2 parts white and 1 part almond is a pretty close match for the original paint, so do so custom mixing on your own just remember the ratio in case you need to touch up spots. I'll probably use an HVLP spraygun since I already have the setup. Later.
#106
Car: 1987 TA and 1989 Iroc
Engine: TA-L98 350 TPI Iroc-LB9 305 TPI
Transmission: TA-Automatic Iroc-WC T5
I like your paint job! What modifications did you have to do to the 4th gen TA spoiler?
#107
Car: 87 GTA
I put on an OEM wing. Drilled new holes, welded the old ones shut.
Some people buy aftermarket ones that fit the stock holes. But they pay at least 3 times the price I paid.
#108
Actually to the original poster but your answer works just as well, Thank You!
#110
Car: 1991 Camaro RS Coupe
Engine: 5.0-liter (305) TBI V8
Transmission: 700R4-speed automatic overdrive
Axle/Gears: stock/2.73
Just a thought here, but I used Zymol for the first polishing of my fin after repainting it. Was very satisfied with how it turned out.
#111
Car: 1985 Z/28 Camaro
Engine: 383 baby!!!
Transmission: NWC T5
Wow I had no idea you could do this. Think it could spray metal flake or is that too complicated? Has any body tried the basecoat/clearcoat yet? I am looking into getting my car painted but this might be better since its so much less $. Any help would be appreciated. Keep up the good work!
#112
Car: 1989 IROC
Engine: 305TPI
I was wondering what the "Hammered" brand of rustoleum looks like sprayed. That seems to have metalflake
#113
Engine: 383 baby!!!
Oh yeah I forgot about that stuff. I have a couple rattlecans of it around here somewhere but I have only seen grey and black colors. I'm thinking of doing blue with one or two stripes down the middle. I'm probly going to paint on the stripes around the bottom too.
#114
Car: 86 Trans Am, 92 Firebird
Transmission: TKO600, T5
i can imagine that it would look awful, probably come out with the hammered finish. I guess if you want you car to that that "olde tyme" wrought iron look, it would be the way to go.
#115
Car: 1984 Camaro
Transmission: 350 Turbo
I painted my 1984 Camaro with some sort of Industrial Paint, Some guy on Craigslist Selling 5 gal buckets of paint for $25 a pop. I bought 5 gal of Basecoat, 5 gal of reducer, and 5 gal of clear coat. Using a little of my own suplies, primer, urethane reducer, etc.. I was able to paint this for pretty dang cheap relative to how much paint I have left.
#116
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
the first thing that comes to mind when i hear metal flake is boat paint, dont put metal flake on your car. Dogfrost that doest look to bad for what 100 dollars and some leftovers you had sitn around, props. Im "proffesionaly" painting mine in our garage tommorow if yall want pictures, its not budget or cheap but ill post em
#117
I've experimented with this (with an HVLP gun) quite a bit (don't remember if I've said anything on this board), but:
- as far as thinning, differnt colors are somewhat different (the biggest difference is the aluminum/siver paint), but in general, mineral spirits mixes better with it, acetone works, but it tends to settle out of it quickly. What I use depends on weather... like normal automotive paint, you use different reducer for different conditions. Nothing, or just mineral spirits will dry _very slowely_ to the point of almost not drying when you get down around 50*F, in contrast, acetone drys quickly, and when added actually accelerates drying/hardening, even under cold conditions. I've gotten mostly acetone to work in 15-20min in 45* weather, but I always use some mineral spirits to get it to dissolve/mix well
- automotive enamel hardener works great with the stuff, also increases gloss and gives it UV stability. Just don't leave it on anything without cleaning, unlike without it where the stuff sits around and drys, with a hardner it suddenly kicks and you have a solid lump of paint.
- you want to color sand as soon as you can without hurthing the surface, wait a few days when it starts getting _hard_ and you'll have MUCH more and MUCH harder work color sanding and especially buffing. OTOH, don't wax for at least a month or so.
#118
#120
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Looks pretty good, regardless of cost!
Glad you 96'd the roller version though.
I painted the windshield surround black as well, but I used semigloss.
It flowed more with the T-Tops
Nothing is wrong with creativity
#121
Car: 84 z28
Engine: 383 stroker
Transmission: th-350
Axle/Gears: 3:42
I read the entire Mopar thread about using the rust paint and there was one dude who "upgraded" to Interlux Brightside Polyurethane boat paint. The shine was incredible for what paint it was and it's really durable, since boats are subject to prolonged uv, salt, weather, etc.
If I do paint my car, it'll be with the Interlux paint, alot better than rustolem but cheaper than a "real" paint job.
#122
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
UMM, any of you guys ever hear of single stage urethane? i painted my old k10 with a gallon of it. $80 for a gallon of white ppg paint, and it doesnt orange peel out the ying yang like rustoleom does
#123
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
UMM, yeah I've heard of it. I tried the Rustoleum at the time just to see what kind of results I could produce. I have since sanded ALL of it off and repainted the car with implement paint.
I DO NOT RECOMMEND USING RUSTOLEUM!!!!!!
Sure, it looks great when it's waxed, but it requires ALOT of maintenance to keep the shine.
Check out the link in my sig for a MUCH better alternative.
#124
Car: '91 Formula (semi-project)
Engine: 5.0 TPI
Axle/Gears: 3.42 Posi
#125
Engine: LT-1
Are you planning on rolling it? I really feel sorry for you. That's really gonna suck. I know, I tried that too. I hope you budgeted at least $150 for sand paper and have a couple of weeks to sand it.
Pleas read the entire first post in this thread. And check out the thread that is linked in my sig. I was the guinea pig for this method on this site. I went through the headaches myself and I'm only trying to save you the headaches and frustration that I went through.
#126
Engine: 5.0 TPI
I know, man. I've read this thread (and many other paint threads). I think your car is great. You found your own way, and I applaud that. I literally do have no good place to spray it, though. My driveway is just long enough to fit the car into with a few feet in front and behind. It empties onto a one lane one-way street that has cars parked on the opposite side, and the neighbor's house is about 15 feet off to the side of it. I don't want to risk getting overspray all over other people's cars and property.
So, yes, I'm going to give the ridiculous foam rollers a shot. I have lots of sandpaper and time. I don't really plan on having the car on the road until this time next month. I want to at least attempt doing this myself, and I've kind of taken a "damn the torpedoes" attitude. I know it's going to suck, and it's going to be a ton of work, and even in the best case scenario it's probably not going to look as good as if I'd sprayed it (particularly since this will be my first attempt at painting a car). But it is going to look better. And, hey, you work with what you've got, right?
#127
Car: '86 Z28 Aged Yellow
Engine: LG4 305
Transmission: 700-RIV
Mad decent.
When I blow out my candles I'll wish for the cojones to do this to my car..
#128
Car: 1988 gta,other cars1963 grand prix,
Engine: 350 tpi
Transmission: 4 speed automatic
Axle/Gears: 3:42 posi
Thanks to this web site I painted my 1988 GTA with massey ferguson red enamel,with reducer and catalyst it cost me 62.00 dollars,I was lucky and have a brother who supplied the sand paper and sealer,and also had a dad with a heated shop,I painted this car in 2 days,check it out on my pics or look up tropicjester12 on youtube!
#130
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
