Need pics of P245/45/16 on Camaro or T/A
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1983 Recaro T/A
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
Theres a Tire shop in the area with 2 P245/45/R16 Tires for sale. I already have New P245/50/R16 tires in the rear. Anyone have a pic of my set up? How low will the front be? Anything I should look out for?
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
Re: Need pics of P245/45/16 on Camaro or T/A
they will fit fine... a budy of mine put the same size on his old 92 z you cant realy tell a difference at all...
Engine: L69
Transmission: MM5
Axle/Gears: 3:73
How significant will the Rake be?
Car: 86 IROC-Z
there wont be any type of a rake at all.. the tires will look the same as 245/50/16 you wont realy see a diff at all...
1 Post
Car: 91 RS
Axle/Gears: 10 bolt
The sidewall difference is only 5% (0.5'') between a 45 and a 50 on a 255 tire so it is barely noticeable...
Car: 1990 camaro RS
Engine: forged 383,8.7;1 200hp nitrous
Transmission: t56 6 speed
Axle/Gears: quick perfomance 9 inch with 4.11s
they do fit just watch ,,,because i put those exact size tires on mine and when i turn hard right it rubbed on the inside of the fender well...
