How do I get this baked on wax off?
Old 02-03-2008 | 07:11 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Axle/Gears: Uh, Haven't investigated this yet
The guy that owned my car before me must have waxed it up for the for sale pics. He rubbed the film off of the hood but nothing else it seems. When I first got it I thought that the paint was just faded. Two days later of sitting out (was in a garage) it got rained on and my black car became white.
I finnaly got my car to the house yesterday and tried taking soapy dish water to it to get it off. It didn't help. The white came back after drying. We took some rubbing compound to it (real light stuff, turtle wax brand) and it started to make it go away. Basically took whiteness out now there is a hase on the paint.
I believe the paint is still good on the car. The hood looks great(nice and shiny) but thats because the previous owner actually finished the waxing process on it but nothing else.
Whats are your Ideas
Old 02-03-2008 | 08:38 AM
badazta87's Avatar
Car: 87 GTA
Engine: Under Construction
Axle/Gears: 3.70:1
Re: How do I get this baked on wax off?
I would start with a clay bar. Follow that up with a high speed orbital and some medium swirl remover, then to a light swirl remover, then polish and wax..
Old 02-03-2008 | 10:56 AM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
one time someone told me to leave the wax on my car for a day so it would soak in the paint... i never did so much rubbing in my life to get it off!!
Old 02-03-2008 | 02:34 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Are you sure it's not just paint oxidation? Regardless, I'd get an orbital buffer with some swirl remover as stated above and go over the car. If you don't have a buffer, you can go to autozone and get some swirl remover and try going over it by hand. By your not going to get the best results unless you use a porter cable.
Old 02-04-2008 | 10:39 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I thought it was faded when I got it. Everything except the hood. the next day after I took this picture it turned white. I believe due to the rain.
We used this really old rubbing compound on it yesterday. Started to get rid of it I was using a buffer though. (G/F's Elcheapy walmart buffer) I don't want to burn it up.) It took 3 min to sorta get a 6 by 6 spot to shine. Put some scratches in it though. I just need to get the old wax off.
Old 02-05-2008 | 12:11 AM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
Try the Meguiar's thrre step?
Cleaner (what you need)
Polish
Then seal (wax)
Old 02-05-2008 | 12:32 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Hmm, looks black. Haha, surprise? Lets see some pictures of it in white.
Old 02-05-2008 | 01:00 AM
karl's-92'-z28's Avatar
Car: Too many cars
I say if theres a Detail shop take it down their or a body shop & see what they say. They should know about those kinda of things, instead of you buying all kinds of stuff, using them & the problem is still their.
Old 02-06-2008 | 08:49 PM
88eyeroc's Avatar
you could go to your local auto store and get some wax and grease remover that should def take it off, but when you do that plan to wax or do the meguiars 3 step immediatly after,,,if you take it to a detail shop theyre going to try to sell you on a chemical clean and a wax...locally in my area this costs about 300 bucks for something you could do yourself...try wax and grease remover its like a mild laquer thinner that uses a wipe on wipe off method it will be located with the body/refinish section
Old 02-06-2008 | 09:33 PM
Car: Too many cars
I would just repaint the car..hahaha
Old 02-07-2008 | 11:23 PM
badredbrd89's Avatar
Without seeing the car to tell whether it's oxidation that could or could not be polished out, if you think its wax, use white vinegar or a wax and grease remover. However, realize that if it sticks around, its most likely oxidation and will have to most likely be buffed using a rotary polisher.
Does it come off when you scrape your fingernail over it lightly? Or do you have to apply a lot of pressure to get it to come off? If you need to do it with a lot of pressure, do it in an inconspicuous place.
It's much better to make a determination with a picture. Hope that helps.
Old 02-08-2008 | 10:56 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
If the weather is good enough tomarrow I will take some pictures so you guys can see what it looks like.
Wouldn't a Black car that had paint oxidation turn to looking like a black primer? If so why dose mine have white swirl marks?
Just a question. This is the main reason Why I think it is wax.
Its possible though that the car is oxidized underneath the wax. I used a clean buffer cover and held it on the car in area for a while. When I finnaly got most of the white stuff to go away it wasn't shiney. I believe though that I could still see waxing marks. I just thought of that just now.
Old 02-08-2008 | 10:37 PM
Car: Too many cars
Try wet sanding & then buffing it out.
Old 02-09-2008 | 12:22 AM
88eyeroc's Avatar
if you buff it and your not familiar with wetsanding and buffing stick with like 2500 grit paper...its much easier to buff...especially on black
Old 02-09-2008 | 12:41 AM
joshh44's Avatar
Car: 1990 T-Top Camaro RS
Engine: engineless
Transmission: Trannyless
Axle/Gears: 10 bolt/3.08. soon to be axleless
i was going to say try wetsanding it.
i did that to my last car. it was red but it turned into a pinkish color due to a bad wax job and sitting out in the sun alot from the last owner.
wet sanded the whole car. got i think a 3 step polishing kit. took 2 days to finish it all up. it looked like the gave the car a whole new paint job.
almost look like a ferrari red almost. it was a very nice the way it came out.
maybe try wetsanding.
Old 02-09-2008 | 12:20 PM
Car: 1988 IROC-Z
Engine: 427 SBC
If you're not experienced, I wouldn't wet sand. You also do not know how much clear you even have on there without a gauge. You do not want to burn through the clear.
I'd practice on something else before you do it to your car. If done correctly, it will make a paint job look a ton better (no orange peel). Here's a piece of my car I wetsanded and buffed:
Old 02-09-2008 | 04:23 PM
z28phill's Avatar
Car: 86z28Hotckiss suspension 1LE Brakes
Engine: 355sbc
Transmission: t5 5speed
Axle/Gears: 373
for wax i use windex to get it off lol try it it workes good but you need to polish it after
Old 02-09-2008 | 05:28 PM
I agree with Iroc5.7. If you are unfamiliar with wetsanding, Idk if I would go that route
Old 02-09-2008 | 05:32 PM
KYLE87's Avatar
Car: 1987 Camaro
Engine: 5.7
dish soap shoulda striped it off or like pomolive. I would try a clay bar or a cheap buffer from like wal mart.
Old 02-09-2008 | 06:21 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I'm definatly afraid at this point to do any wet sanding. It has a newer paint job on it due to the Z28 emblem on the back bumper being painted over.
Old 02-09-2008 | 08:48 PM
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
If you are gonna wet sand it, be very careful. Try in a small, hard to see place first.
Since you know that is not the factory paint, there is no way to know how much clear they layed down. Or, it could be a cheaper paintjob that uses single-stage enamel without clear.
Old 02-09-2008 | 11:31 PM
Car: Too many cars
sand the car down , then primer it , then you won't have to worry bout it...hhahaha. Seriously its a toughy issue if you don't know whats going on with the paint, best bet is to ask the previous owner if you can still get in touch with him.
Old 02-10-2008 | 03:00 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
I would try a three step polish system (mothers, meguirs) with a cheap buffer before wetsanding. wetsanding is a pretty involved project. dont use rubbing compound youll burn through the clear and it will just leave the finish dull.
Old 02-10-2008 | 07:16 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Heres a few crappy pics. They looked better on camera than they do now. I just pulled the motor and trans.
Old 02-10-2008 | 09:17 PM
Car: Too many cars
I think you should just get it repainted, so you know the paint wil look good when you take care of it.
Old 02-10-2008 | 10:05 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
I'm planning on getting it painted in the future. Right now mostly trying to make the car move under its own power. after that I'll spend the money on making it pretty. I just wanted to clean it up a bit.
Old 02-10-2008 | 10:10 PM
Car: Too many cars
Not to sound mean but that baked on wax is goona be a biatch to get off. I would just sand it down & primer it for now. If not try using a wax stripper, but use it in a small area, but again you'll be wasting your money on these items if theydon't work.
Old 02-11-2008 | 07:04 PM
Car: 1988 IROC-Z
Engine: 427 SBC
Do you know anyone with a Porter Cable? I'd start with an orange pad and some aggressive polish (like Optimum Compound) and go from there.
Old 02-11-2008 | 08:19 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
My G/F brought home a Dewalt variable speed buffer on friday from her work. We haven't got to use it yet due to it being so cold out. The building the camaro is sitting in isn't heated. We also aren't so sure what speed to run it at yet. Haven't been able to find anything on the internet about it. They also gave her a bottle of some kind of mild polish. They thought it might work. She works for a company that sells Auto detailing products. I don't know how much they actually know about the products they sell. We'll try it though. She also got some kind of buffing pad. I don't know much about this stuff. Its normally "Wax on, Wax off" for me.
Old 02-11-2008 | 08:39 PM
z28phill's Avatar
Engine: 355sbc
Axle/Gears: 373
if it has speeds 1 to 10 put it on 3 or 4 use a Diamond Cut Compound from Meguiar's
link to the Meguiar’s Complete Video Guide Smooth Clay Kit
hope it helps you out
http://www.meguiars.com/video/
Old 02-11-2008 | 08:52 PM
z28phill's Avatar
Engine: 355sbc
Axle/Gears: 373
place thin rings around the pad starting from the outside and moving in to the center. 4 to 5 rings should be great. Place the buffer on the car BEFORE turning it on. Then, without applying more than your hand's weight to the buffer, hold down the power button and apply the cleaner/compound to your car's surface. I usually start on the hood of the car and cover the entire hood before applying more cleaner/compound. I then apply a little more cleaner/compound and work my way around the car, applying more as the pad dries out. Do not apply cleaner/compound to black trim, but don't sweat it when you get a little on there.When you are done applying cleaner/compound, using a clean, super soft, terry cloth towel, remove the cleaner/compound. Be sure to flip the towel to a clean spot once you feel like it is getting "gummed up". You will be able to tell. You will use plenty of towels taking the cleaner/compound and other steps off, so have plenty on hand (maybe 20 or so small 12"x12" towels). Once you have buffed it out by hand and all of the cleaner/compound is removed, you will see that the car is looking pretty good. We are not done yet, it is going to look even better.
Waxing! Ok, now we are actually going to apply some wax to your car's finish. There are two options here. First, is a paste was, second is a liquid wax. I have always been partial to the paste waxes as they seem to leave a better finish, but for the sake of your time and relationships, I have a good compromise. I usually use a combination of liquid and paste waxes. Mind you, I use the professional stuff, but the paste wax is bought at Pep Boys, Auto Zone or whatever. Apply some past wax to a clean buffing pad with a butter knife or small paint scraper. Cover about 50% of the pad with a light layer of wax. You will see that it will spread like warm butter. Then apply some liquid wax from a bottle (be sure to shake well) on top of the paste wax (not too much here) and then apply like you did in Steps 1 & 2. Buff with tons of clean terry cloth towels and you are done. Your car probably looks incredible at this point and you did it yourself.
lol i love google
Old 04-02-2008 | 09:37 AM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Actually got to run the buffer on this thing last night. Its Shining again. There is a Flat feeling to the paint when you run your had over it. I'm figureing I'll get the whole car shining again and continue going over it untill I get it smooth as silk......
Old 04-02-2008 | 06:02 PM
comp's Avatar
post some pics
Old 04-03-2008 | 01:23 AM
88iroc52387's Avatar
IF you have a detaling shop in your area ask them how much an acid bath costs. My buddy does detailing for a bunch of car lots and high end stuff on the side. He gives my 01 camaro an acid bath once a year (strips everything to clearcoat) doesn't harm my clearcoat then does a wax job on her. he only charges like 50 bucks for the acid bath so to a non friend maybe 100 or so which isn't bad. just another option incase the buffer ends up not working completely. Good luck
Old 04-13-2008 | 07:45 PM
Yes, please post pics to show us how it came out. I'm very curious to see the difference. Is the DeWalt a DW849? That would be a rotary polisher which is best when used in a detailer's hands. (NOT to insinuate you dont know what you're doing.) I was just curious what she brought home for you to try. The paint sure looked neglected. You've piqued my curiosity now!
Old 04-13-2008 | 08:51 PM
SouthsideJohnny's Avatar
If you already got it shiny I wouldnt keep buffing on it until you get it smooth. Clay bar and wax instead. Continuing the buff from this point could result in paint burn. Going from the pics I would assume you only have a single stage paint job anyways.
Old 04-14-2008 | 07:14 PM
primerk5's Avatar
Car: 85 Z28 Camaro
Engine: TPI 305
Transmission: 5 spd
Here are some pics of what you wanted to see.
We didn't get real far yet as I just had Head gaskets go on my Diesel truck. So now I have to fix that. (Swear I can't win for losing some times)
Any how, The orange peel looks worse in the pictures than it dose on the car. (I think) You can see looking the roof the spot that hasn't been buffed yet. Then looking futher down the B pillar you can see where We've been working on it. It is no where near done at this point. We just wanted to see what would happen.
At least it will shine untill I get it painted.
Before buffing......
After
Old 04-14-2008 | 09:08 PM
Wow. Night and Day difference. You may be ok for a while if you decide on repainting it in the winter or something. But you'd have to be religious about keeping her clean. Looks 1000% better.
sailtexas186548
02-17-2017 03:07 PM
BADNBLK
Brakes
10-06-2015 02:51 PM
neilb
09-15-2015 05:06 PM
TheExaminer
09-06-2015 11:40 PM
kyleb24
08-15-2015 08:24 AM
Quick Reply: How do I get this baked on wax off?
