spots on my wheels!
#53
Car: sold
Re: spots on my wheels!
I did that to my factory wheels, and I will haveto say they will look nice for awhile, but man they are a pain to keep shinny. once you get them were you want them clearcoat them
#55
Car: 1985 Trans Am
Transmission: 700-R4
well i got a powerball and some other polishes...still nothing...so im going to say **** it and try sanding them...i used some 1500 but it left marks so where should i begin with??
#58
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
have you tried polishing compounds? some tripoli followed by white rogue should have em looking good as new..
#60
I'm really surprised nobody recommended that.. that's normally how you go about polishing rims... do some searches on polishing rims I know there are a few good thread floating around about it.. compounds arn't that expensive.. here is a link to some bars from summit.. http://store.summitracing.com/partde...5&autoview=sku or you could go cheaper and just buy these three http://store.summitracing.com/partde...5&autoview=sku
you probably only really need the tripoli and the white rogue.. you will also need a polishing attachment or two for a drill, shouldn't cost ya too much more. Also I will give you a 100% guarantee that if you compound those rims you will be able to remove those spots and make them shine like new chrome.
#61
Car: 1985 Trans Am
#62
Car: 1985 Trans Am
http://www.sears.com/shc/s/ProductDi...000P&RTIFlag=1 found that for cheap will be picking it up
#63
that should work.. there probably isn't enough compound there to do all the wheels though, it's probably enough to do one or two. Basically you guessed right, apply compound to the wheel, then go at it. It's kind of like sanding in the way you start with one and finish with the other, like switching to different grit sand paper.
#66
Car: 1985 Trans Am
nope....kinda gave up and bought new wheels, there just sitting in my garage right now, im sure if i sanded em down or like powder coated them they'd be fine but there only 15's so they were small anyways
