Identify my wheels if you can.
Car: 1984 camaro
Engine: 2.8l to 383 stroker
Transmission: t5 to th400
Axle/Gears: 12 bolt soon with 3.73s
Re: Identify my wheels if you can.
oh god i have seen them before but where :/
Car: 89' Camaro RS--
Engine: 305--
Transmission: Automatic
Axle/Gears: 2.73--
Lol well if you figure out or anyone else that would be super. I like the wheels i just want to see if i can get some in better shape... but im having a hard time finding the vechile they belong to.
Car: 1984 camaro
maybe 70s firebirds ? im 95 % sure there pontiac rims off something
http://i4.ebayimg.com/02/i/000/b4/cb/1321_1.JPG
Car: 1989 gta
Engine: L98 D1SC procharger twin IC
looks kinda like they came off a pontiac le mans check a 1973
Car: 1992 Firebird
Engine: Stealth Rammed 412 with TC78 Turbo
Transmission: '93 T-56
Axle/Gears: 3.27 9 bolt posi with PBR discs
They look like Pontiac "Rally II" wheels to me! They came on almost everything from the late 60's up through the 70's From GTOs to Bonnevilles. IIRC they also had a variation that came stock on our Thirdgens. I seem to remember seeing a Pontiac brochure picture from '85 or so with those wheels. They are nice looking wheels when reconditioned!
-Paul
Edit: This is what Rally II's look like in their original (GTO/Early Firebird vintage) form:
-Paul
Engine: 305--
Axle/Gears: 2.73--
Know a place to get them new like that one??
-Paul
-Paul
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
As Quadgoat noted those are Pontiac Rallye ll wheels used from '67 up on every Pontiac produced(even the T1000 had a version I believe).And I've seen pictures of 3rd Gens with them in brochures but haven't found one to post yet.Pontiac was phasing out the Rally 1 wheel that was being used on the GTO and Tempest among others.Also they came in both 14" & 15".And either with the PMD center cap or with the Pontiac arrow in a polished and brushed finish.And some years trim rings were standard and some years they were not(depending on the model).
Online170 the wheel you have pictured was a Z28 only item that used a thinner outer trim ring than the Rally ll.That wheel was used from '70-1/2 on the Camaro(and it had a similar version used on the Chevelle).
Coker Tire,Classic IndustriesYear One among others sell the reproduction wheels,trim rings and center caps.You should be able to find them in a J-yard as stated they were optional on every RWD Pontiac.Just check the back for the size(15X7 was the largest factory made -but you can buy larger aftermarket I believe).As you can tell the Cragar SS was the inspiration for the wheel style.
Car: 1994 Trans Am - 1992 Firebird
Engine: LT1 5.7 V8 - 3.1 V6
Axle/Gears: 3.42 / LSD
My neighbor (big 2nd gen TA enthusiast) told me the casting number on the rim would tell what they were off of but I couldn't find any info with it...but they all seem to be the same rim as someone already said
Did you get the 307 running right?
Engine: 305--
Axle/Gears: 2.73--
Well when i got it home i rolled it off the trailer. So it sat in the yard.. Then i worked on it and got it running long enough to go from my yard to the garage. Pulled the engine and tranny and cleaned everything from inside and sold it to a guy in the thumb who plans on building i belive a drag car out of it.
Car: 1991 Z28
Transmission: 4L60 automatic
I'm almost positive they are from a mid 80's base firebirds .I've seen them on them before.
Car: 1991 Z28
..or maybe from a '74 formula or
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
Car: 1988 Iroc
Engine: 383 TPI
Axle/Gears: BW 9 bolt 3.27
For sure not a `73 Pontiac Le Mans or Tempest, I had both new and that wheel was not around then, both models had a transaxle.
Sorry to double post, I was 10 years off. I meant to say 1963, not 1973.
Car: 1992 RS
Engine: 3.1
My friend had them on his 86 GP. That would mean they should be a direct fit without adapters.
They are called Rally II wheels.
Pics:
http://www.pontiacserver.com/gph3_9.html
Pics:
Car: 1984 RPO "Y84" Recaro T/A
Engine: HO 305ci L69
Axle/Gears: WS6, J65, GT4: 3:73, G80: posi
I found a set of those on a early '82 - '84 Firebird during a junkyard raid, but I dunno if they were stock. My '83 Grand Prix LJ had a set of those Rallye II's, the 15" versions, & they had a Pontiac Arrowhead on the center cap. I'm positive they came stock on that car. I bought it off an older gentleman for $800 who bought it new. He was having a hard time seeing & side-swiped the pass-side door against something. It was an awesome car, but she had a serious frame rail rotting issue and the typical G.P. doorskin cracking problem. I parted her out 8 months later, but I kept the Factory tachometer & guage cluster.
