Sap Removal, once and for all
I parked under a tree that literally sprayed a film of sap ALL over my car. I read a ton of posts here that said to use WD40, Alcohol, Turtle Wax Bug and Tar Remover, etc. Finally, I read a post based on vinegar. I tried a ton of the solutions, but here is are my trials and errors and what finally worked for me.
[B][B][B]
No. 7 Bug and Tar Remover- Sucked. Didn't do ANYTHING. Getting my money back.
Alcohol- very difficult to use, had a very tough time dissolving the sap.
WD40- worked okay, but removed wax, and I was worried about what else it'd do.
Concentrated car wash- I didn't like the idea, but I did it anyway. As always, it removed wax, spread the sap, but eventually got it out.
Water and vinegar- This was my ultimate solution. The diluted vinegar cut the sap like you wouldn't believe, and left the wax intact!
I took it one step further and made a cocktail that worked EXTREMELY well. 1 cup of vinegar, diluted into your usual car wash. I couldn't have asked for anything better. Where there was still wax, the wax remained, and all of the sap and the dirt accumulated washed off with ease!
[B][B][B]
Car: 1986 Irocz28/04 GMC Yukon
Engine: Ram Jet 350(*TPI*)
Transmission: Turbo 400 w/1500 stall
Re: Sap Removal, once and for all
I USAULLY USE LAQUER THINNER AND THEN GLAZE IT AGAIN WORKS FINE ...BUT IF THAT WORKS LOOKS LIKE I CAN TRY THAT INSTEAD....
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 91 formula ws6
Engine: 1 peice roller scat 383 4 BOLT!!
Transmission: 5 speed
i used a baby skin lotion,,, it worked better than paint stripper!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 91 Trans Am
Engine: LSA
Transmission: T56 AWD
Axle/Gears: 8.8 4.10
Pepsi
50/50 mix in your wash bucket then wash the car again with normal soap and wax twice afterwards because you wont have any left
Car: 1995 Formula; 1976 Trans Am
Engine: LT1; None
Transmission: T56; None
Clay detailing bars can also remove sap, as well as deep-clean the rest of the paint.
Car: 87 Camaro sport coupe
Engine: 2.8L its so cute!!!
Transmission: Automatic
Axle/Gears: ???
my car that I bought sat under a tree for 8 years I have a ton of sap on my car in big globs I'll have to try this. the thing I worry about is getting the sap off the glass
Axle/Gears: ???
I read on the bug and tar remover you can buy it warns not to use it on glass!! I like the idea of vinegar I hope that won't cloud the glass in any way shape or form LOL
