Refinished my GTA rims with pics
Old 05-05-2007, 05:18 PM
The_Wraith's Avatar
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
These rims came off a 89 GTA that was highway driven since new and never washed .Being in canada this horribly tarnished the rims. I decided to try and restore them and here is the results.
Materials needed/price
Aircraft stripper (jug) $30
Cheapo paint brush $1
1 bag of very fine steel wool $2
plastic scraper $1.50
Masking tape ,free
rags,free
I wanted to save the gold centers as they clean up nice when washed. I did all this in my apartment buildings parking lot with no access to a hose. I brought out a bucket of water. Mask all areas off! Basicly you spread a coat of the air craft stripper and you immediatley start seeing the clear coat melt off. I used 2 coats to be safe. After that I washed the area off with a wet rag then scrapped the bubbled clear coat off. Most of the areas on my rims had corroded past the clear coat and heavily into the aluminum. From here on its polish away all bad areas with steel wool. This was no easy task. Two rims took me the better part of the afternoon and my hands are killing me lol. After you are finished ang get the desired amount of corrosion off wash ,dry and use mothers aluminum polish on the area. I did two coats!
Now for pics I vgot one side of the car done so its mixed front and rear pics
Before:
Now:
(stripping process)
After a good polish:
Old 05-05-2007, 06:01 PM
rwdtech's Avatar
Car: 1991 Z28 (sold)
Re: Refinished my GTA rims with pics
omg makeover!!!
Old 05-05-2007, 10:15 PM
ShowNGo92's Avatar
Car: 1992 Firebird
Engine: 305 TBI
Totally awesome job!! Now I really want to do mine.
Old 05-05-2007, 10:19 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Wow, great job!!
Old 05-05-2007, 11:32 PM
Z_wonderer's Avatar
Car: 86 z28
Engine: LB9 305 TPI
Axle/Gears: 2.73 gears
thats cool man!!. will that work on wheels with paint on them like Z28 wheels?
Old 05-05-2007, 11:58 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
Looks great! Where did you get your aircraft stripper from?
Old 05-06-2007, 12:25 AM
Tmic87TPI's Avatar
Car: 1987 Trans Am
Engine: 355
Transmission: t56
Old 05-06-2007, 07:47 AM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Yep I don't see why not. I had to mask off my gold centers well so the stuff would not eat through the paint. You can get the stuff at NAPA they sell a large jug for about $45-50 canadian. I got the same stuff at a body shop place for $30. You wont even use half of the jug for 4 rims. I will snap a pic of the stuff I used.
Thanks for the comments.
Old 05-06-2007, 10:30 AM
zdc590's Avatar
Wow, my camaro rims look kinda like yours used to, i guess ill have to look into that, those look great. How long did it take you to get it all done?
Old 05-06-2007, 02:17 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
I did 2 in about 5 hours (in the sun) lol so that wore me out. I did the others today in about 4 1/2. A little tip you can sand away deep pits with 600 grit wet sandpaper. After you get them out polish the area with the fine steel wool. I got mine from home depot the finest wool they had. Forgot to grab a pic of the stripper but I will tommorow. Another pic
Old 05-06-2007, 02:46 PM
JDud's Avatar
Man that looks sharp!
Did you clear coat them afterwards?
I am going to have to do that to the insides of my IROC rims now....
Old 05-06-2007, 02:47 PM
zdc590's Avatar
So i guess this is a weekend kinda thing huh? Guess ill have to wait another few days before i cant start mine. Once again those look great man, nice job.
Old 05-06-2007, 03:19 PM
The_Wraith's Avatar
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
YEP definatley leave the weekend open so you have plenty of time to do this. It is allot of work. I did it all by hand no machines. So all surfaces are even and nothing is "overdone". Once its all said and done you will be happy with the results! If anyone gets into it and runs into anything drop me a line and I can help.
Nope they are now polished aluminum. I used 2 coats of mothers polish available at most auto or department stores. No clearcoat is ok. Some rims comes factory with polished aluminum.
Here is another item that helps get the job done on a hot day!
Thanks for the comments!
Old 06-25-2007, 02:05 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
A+ thread.
I would recommend this one for a sticky if the GTA rims were more popular than they are already. I'll be using these instructions soon.
Old 06-25-2007, 02:23 PM
rwdtech's Avatar
Sleeman? how about Killians?
Old 06-25-2007, 04:41 PM
TGO - 10 Year Member
Street Lethal's Avatar
Awesome work Gnarley!
^ Sleeman, ehh?
Old 06-25-2007, 10:09 PM
MillerTime21's Avatar
Car: 94 25th TA
Engine: 355LT1
Axle/Gears: 10bolt 3.42
Looks good, this motivates me to go do mine now.
Old 06-25-2007, 11:34 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looks great
Old 06-26-2007, 10:51 AM
8T9 BANDIT's Avatar
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
how did u mask off the tires? ive also been wanting to do this, but i thought i had to remove the tires, and thats a big pain in the a**.
Street Lethal
04-30-2019 12:14 PM
Exxon Limited
Camaros Wanted
22
12-21-2015 10:36 PM
Djmathis123
09-29-2015 01:36 AM
rh76camaro
08-29-2015 11:04 AM
Exxon Limited
08-09-2015 08:13 PM
Quick Reply: Refinished my GTA rims with pics
