Hi Temp Clear Coat over pinstripe on a plenum?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 85-Vette
Engine: 406ci
Transmission: TKO-600
Axle/Gears: 3:45
I put some machined grooves slots in the top of my Stealth Ram
Can I put pin stripe in the grooves, then put Hi Temp Clear Coat over it and obviously, will it stay?
1 Post
Car: 92 Z28
Engine: Boosted LSX
why not paint the groves and then clear it? id be worried pin stripe might not hold up. maybe put some on and see how it holds upto the heat 1st. Then clear it all.
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Hey Chris, I pretty much knew the answer but hoped that someone had tried this already.
I will lay some paint in the grooves then shoot some hi-temp clear on it.
I am tempted to let you powder coat the grooves then let your buddy polish it, then clear over all of it.
Larry
Car: 85-Vette
Engine: 406ci
Axle/Gears: 3:45
Soutside of the 465 loop,, I-65 and Southport Road
https://www.thirdgen.org/forums/alte...fit-under.html
gta892000
09-16-2015 12:37 AM
