vht flameproof paint 1500*
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
has anybody used this paint for there exhaust system? i wanna paint my exhaust and mufflers cause there gettin shitty lookin and worn... pics would be cool to...
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
ive used some on my edlebrock headers but it was only like 500 degree paint but it was like rustoleum or something. it has held up preety good on the headers you just need to prep the area really good. i put 2 or 3 quotes on them. now the y-pipe hasnt held up too great b/c it is close to the road so idk how the exhaust would turn out.
1 Post
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
That POR 20 exhaust paint is pretty nice. My dad used the velvet black and I have used the aluminum. Both went on easy and look nice. I would suggest spraying it on rather than brush since it leaves small streak marks.
Car: 1991 Camaro RS
Engine: LO3
Axle/Gears: 3.42 LS1
So if you have aluminized pipes, should you remove them, and sand them down real well to bare metal before painting them ? Because they already have a coating, so to say
my y pipe is rusting, should I pick some of that up and sand the pipe down then spray it with that? or should I prime then paint
Car: '88 IROC-Z medium orange metallic
The VHT paint is good stuff if you use it properly. I've had it on my headers for a year now and I've done all 5 sets of our dyno headers with it and they've been 3 years now.
Clean and dry the metal real well and apply the paint in many thin coats. I use 2 full cans for each set of headers. Let it flash between coats for about 5 minutes. Once you're done let them dry overnight. Then you need to cure them. I use a mapp gas torch and heat the headers slowly until the paint "melts" and takes on a glossy appearance. Once you get that wet look let them cool. I do this 5 or six times before I put them on the car. When you get them on and fire the motor look for smoke. If they start to smoke, shut the motor off and let the headers cool. Keep doing it until they don't smoke. Sounds like a lot of work but it's not bad. I know people that have used the VHT paint and not cured it and the paint just fell off in a day or so.
Re: vht flameproof paint 1500*
I just painted my shorty headers with it for the second time. the first time, i 'tried' to cure the paint in the car, didn't work. Paint fell off after driving it once or twice, then they started to rust. This time i cured them in my bar-b-q. Heated them to 250 for like 15 minutes, let them cool. Heated them to 450 for like 20 minutes, let them cool. Heated them to 550 for like 20 minutes let them cool. They look pretty tough now, and i didn't leave any hand prints on them when i was handling them... The finish looks pretty durable this time. I will let you know how they work out
Car: 1985 Sport Coupe
Axle/Gears: 3.08
maybe thats where i went wrong, i tried doing it on the car too and now cant even tell on the y-pipe that i had painted them on the headers you can still see it kinda
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
My brother painted his hooker headers with that paint and it worked great. Sanded them down with a Da and got everything pretty much off of them. Then he painted them with the Vht and burned them in by putting them on the car, letting them get hot from the engine and then turned it off burning the paint on there. its been 6 months and its held up really well
Hotrodboba400
12-10-2019 07:07 PM
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
sailtexas186548
02-17-2017 03:07 PM
