Door Panel Help Please
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1989 Firebird Formula
Engine: 350 ZZ3
Axle/Gears: Stock
I'm taking my door apart to fix the power locks. But now i've decided to make all new door panels. The Problem is that i can't get that black piece of trim off of the top of the door. My haynes book doesn't say how either. Thanks for any help.
89 Formula 5.7L
ZZ3 with some good mods
89 Formula 5.7L
I'm having the exact same problem with those black metal, like washers holding the black plastic piece on top of the door panel. anyone changed these out before???
put your window all the way down. Push down and in on the plastic and try and lift from the edge,it should just lift right up then...
92RS,POLO GREEN
[This message has been edited by kermit_one (edited April 02, 2001).]
92RS,POLO GREEN
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
window down and wiggle it up...carefully. Although you can kinda ignore the carefully part, those panels are a dime a dozen, at least in PA anyway.
Hotrodboba400
12-10-2019 07:07 PM
