How awesome is your underbody?
#51
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
hihighost: Don't worry about living up here. I do too. I was the second one to post, if you are not familiar with my car allready. It is tough, but if you take care of it, you can have a car just as nice as any of them on here, it just takes more work.
When my car was stock I would drive it straight through winter, non stop. Hell the damn front GFX used to plow the road when we had blizards. The main thing I did to stop any damage from propogating was to park in a garadge. I even used a friends garadge sometimes when I couldn't use mine. (lived close by). The every saturday morning, I would put it up on jackstands, wash and wax the whole car, in the garadge with a bucket. I would then clean as much as I could from under the car. A garden hose goes a long way. Get that salt and grime off as soon as possible. And you are generally OK.
The motor I have in the car now, won't really let me drive it in the winter, but maybe someday when I get EFI and tame it down a bit, I will be out there, plowing my way down the road. Oh yeah, I also would have to put the heater back in the car, haha.
Clean stuff up and POR-15 it. The right way. And you will be just fine. The more carful you are, the longer things will last. Don't let New England hold you back...
#53
1 Post
Car: 1989 Firebird Formula
Engine: 305 T.B.I. (Vin tag "E" = LO3)
Transmission: THM-700-R4
Axle/Gears: 10 bolt posi 3.23
My car is michigan born n raised, seen 2 winters in its lifetime, faimly owned since 95 n then it had only 36k on the clock.. (now 108k) rear end is still black, some thigns gotta be a lil crusty but the stuff described is clean
#55
Engine: LS3
Nice. Stainless right? Looks good, but I kinda don't see how come you went next to the tranny on one side and then under the frame on the other? You are still gonna have that be your low spot.... Oh well either way, i am sure it will work out fine. I thought of going next to the tranny till I thought of the heat. Then I went under the x-member. Now looking back, I might want to try next to the tanny next time and use some good heat wrap.
#56
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Undercoat and POR-15
Wow, the cars look great! I am right in the middle of a full restoration and I have just finished patching my rusty floor boards. I was going to under coat the car or use POR-15. What is the benefits of POR-15 over undercoating? The floor boards are rust free no (after hours of welding) and this car will not be driven in rain or snow.
#58
Engine: LS3
POR-15 is an undercoating. There really is no difference. You paint it, or spray it on and then it gets really hard. Thats it. What undercoating were you considering? I really like POR-15 cuz it looks like paint, but coats like an undercoating.
#61
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
tci transmission pan. the only problem if you have bad ground clearence the transmission pan willl scrape every once in a while over speed bumps if you don't go slow enough. thanks but i think i want to paint the bottom of my car like 406tpi's car
#63
Re: How awesome is your underbody?
Did anyone have those plastic rails along the sides under the car? Mine does, I guess it's some sort of dust guard?
#64
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
wow, talking about raising the dead, lol. This post is so old that most of those pics don't exist anymore, right when I wanted to see them, lol.
#67
Well does anyone happen to have pictures of their underbody done up with the POR-15 that everyone has been talking about? That's really all that I have been wanting to see anyways.
#68
POR15 won't stick properly unless you etch the bare metal, sandblast it or if it has rusted. It needs the rough texture to hold. POR is based on isocyanate sort of like super glue.
I used bedliner on mine, IMO it comes out much nicer than por and you don't have to prep anything apart from cleaning, degreasing and you can leave the original e coat in place. Just touch up surface rust with a little epoxy or whatever you want and then apply the bedliner (I disassembled everything so I could do the whole underside)
![](http://www.vettemod.com/forum/imagehosting/24b538b3111bf0.jpg)
![](http://www.vettemod.com/forum/imagehosting/24b09b6ebeed33.jpg)
#69
1 Post
Car: 89Z28 Vert
Engine: 350/tbi
Axle/Gears: 3.27 Posi
that is one great bottom you got there buddy the whold thing looks great and the bedliner not a bad idea imo
#70
#72
Engine: LS3
What kind of rear suspention is that? Never seen it before.
#74
#75
#77
LOL thanks, I understood that much, I was referring to how it did it so much better than say the Spohn boxed panhards. Why does the rear end look like it is bolted to the framework in one of those pictures? I'm not trying to be a pain, just want to understand it and use it if I might need it later on.
#78
the normal panhard bar layout moves your rear axle side to side with suspension travel, a watts linkage has a z type linkage that allows the axle to move up and down with no lateral movement. What you think is bolted to the frame is actually where the side arm is bolted to the pivot with a heim joint. the axis of the center pivot is height adjustable on the multi hole section in the middle, it's on the top hole now but I need to adjust it after the full weight is on the suspension to get the arms level
#79
Either way, this would be really useful in a track car or a SOLO2 car where the car is thrown sideways quite often and a lot of stress put on the panhard.
Do I dare ask how much that cost?
#82
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
Did the cost on the watts link include every bracket and link in the picture?
#84
Damn, that is really interesting...but not right now, lol. The engine and transmission are more important right now, but maybe I'll spend that kind of money on one piece of suspension once I get to the point of really needing no movement in the rear end.
Abubaca
11-05-2016 12:22 PM
