Are the side molding pieces painted or colored to make your paint?
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
Are the side molding pieces painted or dyed to match the paint?
I'm talking about the rubber pieces that go down the side of the car in the middle. Are they painted when the car is painted or are they dyed/colored to match the color? I was fixing to start sanding mine down so I could paint them to match with the Dupli-Color spray paint, and I noticed that they don't look painted, they look like the rubber itself is red. Can I just buy new pieces or will I have to go ahead and try and paint these?
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
The color is all the way thru on my black ones. I had a set of green ones that was the same way. You can paint them if you want. 1k paint will oxidize fast though and scratch easy.
If the color is right i would just buff them back out to a nice gloss. Some paint cleaner and polish will make them shine like new. Maybe even some 1500/2000 grit first if there really oxidized. Buffer would be faster if you have one.
Car: 2012 Corvette
Engine: LS3
It looks like mine are red all the way through, but it looks like at one point when the car was repainted at least one of the small pieces was painted (it was taken off the car when it was done though, there's a new piece of adhesive over the old one and the paint cracked when I bent it). The two long pieces, which don't appear to be painted, are oxidized very bad and I don't have a buffer (when I get one I need to polish my taillights too).
I guess GM doesn't make these any more?
Car: 1992 Jade Green---Trans Am Converti
Originally they were color matched, now they are paint to match. GM had them a year ago, but I don't know about now.
Kevin D.
Kevin D.
1992 Trans Am
05-10-2023 07:19 PM
ElPaleterro85
08-13-2015 03:49 PM
