Eibach Pro kit installed pics inside
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Got around to putting my springs in the other day with the help of a few of my friends. It really wasnt a bad job at all, just took a little while.
Dropped the car down about 1.5" and i also installed a Hotchkis adjustable panhard at the same time. When i let it down from the lift, the rear had shifted to the drivers side some, so the adjustable bar was necessary. I adjusted it to the center and its fine now.
here's a couple quick pics
![](http://memimage.cardomain.net/member_images/10/web/262000-262999/262003_753_full.jpg)
![](http://memimage.cardomain.net/member_images/10/web/262000-262999/262003_754_full.jpg)
![](http://memimage.cardomain.net/member_images/10/web/262000-262999/262003_757_full.jpg)
![](http://memimage.cardomain.net/member_images/10/web/262000-262999/262003_759_full.jpg)
![](http://memimage.cardomain.net/member_images/10/web/262000-262999/262003_760_full.jpg)
1 Post
Car: 92 Z-28
Transmission: THM700R4
very nice! Really sharp! You must be really proud of that car. In dropping it 1-1/2", what size rims and tires did you use?I'm trying to put together a combo for mine. Did you always have them on? Were you always planning on dropping it? typical newb ?
Car: 1991 Z28
Transmission: WC T5
Axle/Gears: 3.73 Posi
My Zed with original springs looks pretty much the same. Mind you they are soft as mashed potatoes.
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Thats hot...
looks really good man! That car has really come together nicely.
Wonder what it would look like with a body colored grill.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Those wheels made that car! Springs look good, and glad to see someone went with something other than Boyds....
Car: 2012 Corvette
Engine: LS3
Transmission: TR6060
That looks really good. My car really needs a drop, but I'm still not 100% sure I want to do it. I scrape enough as it as, but I'm not sure if it was the ground effect or the lower air dam (if it's the air dam I don't care). Those lowering springs are fairly cheap too. Definately on my consideration list.
Car: 88 IROC
Engine: 305 TPI w/ l98 cam
Transmission: T5 5-speed
Axle/Gears: 3.45 posi disc 9 bolt
very very nice car man it looks great with the wheels and springs i like that kind of look alot better than the drag look you had b4 with the prostars. those springs will probably settle a little more if they havent already. ive got intrax 2" in my car. did you do the lca reloc. brkts. too? how is the performance any difference?
can i get a full size shot of the third one from the top to my e-mail. its maroon88iroc@yahoo.com
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
just gets better and better!
you have relocation brackets yet?
1 Post
maroon88iroc i will email those pics tomorrow !
I havent put in LCA relocation brackets yet, the car doesnt wheelhop... it seems to just spin forever. But it is on the to-do list
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
that looks hot with those wheels, i havent been online much and musta missed a thread about your new wheels, it looks awesome . i like the look .
Car: 2012 Corvette
Engine: LS3
Are they really needed when you lower the car? I only have a V6 so it doesn't spin too easily anyway, but when it does there is a little wheel hop now.
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Looks very sharp, it has that pro touring look now. I'm loving your car more and more every time I see it.. I had to look to actually see your ghost flames and yet I can only see them in a few shots. I love that. I wonder if ghost flames would work that well on a black car?
I must have lucked out because when I installed my sportlines my rear end shifted less then one centimeter, which is no big deal, so I went with a non-adjustable panhard bar.
1 Post
Brisk - ghost flames can be done on black paint but it is alot harder from what my painter friends tell me, because the pearl shows up alot more. Best bet would to use a candy ghost flame i think...
thanks everyone
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Can we get a side shot?
i've got sportlines on my brid and it doesn't look as low as some others I've seen with sportlines. Looks almost like I have the pro-kit, but my springs were red.
![](http://www.transamws6.com/pics/formula/formula-8-26-2.jpg)
1 Post
Heres a side shot, not the greatest because of the shadows but it gives an idea
the car handles and drives alot better with these springs on MA roads despite being lower. the whole car feels better
something to remember is that your formula has no GFX and will give the illusion of being a bit higher off the ground than tunedport335's Z28.
tunedport335: i never told you the car is looking amazing. just went right into the technical and never gave you the compliment due! lol! anyhow, keep up the good work, and make sure you get some new times yo!
1 Post
Yup all the time. Roads up here are pretty bad, you gotta keep your eyes peeled 24/7 or else you'll end up with some bent rims
![lol](https://www.thirdgen.org/forums/images/smilies/lol.gif)
SnkSknrZ28 - no more drag car huh? Should look good though
Zepher - your car sits slightly lower than mine. Mine still has to "settle" though i suppose
toronto formula
11-10-2015 06:17 AM
