Few pics of the Twin Turbo car..
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
Grabbed a few pictures of my friend Pauls '83 Z28 tonight. Just about done with it, for the 2nd restoration. Some of you may remember pics of it before. Since then it got a new paintjob (same scheme with the overlapping flames), wheels, interior, glass, etc. Theres still a few things that need to be finished up, but for the most part it is together and running. Here's a quick run down of the specs ..
- Dart Little M block 383ci
- Dart Pro1 215cc heads
- F.A.S.T. EFI engine management
- Twin Master Power T60-1 turbos
- 3" true duals in the stock location over the axle
- T56 with spec stage 5 clutch
- Currie 9" rear
- Coil overs up front and Hotchkis supsension in the rear
- Corvette C5 brakes and 17x9.5 torq thrust 2's
Its a little dirty in these pics but i did the best i could... i will get better ones for you guys in a few weeks or so. PS take notice of the flush door handles Anyone wanna take a guess what they are from?
- Currie 9" rear
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Absolutely beautiful car. Its got the complete package. ANy 1/4 mile passes on it yet?
IIRC, it used to be carbed, what made him decide to change? (I know EFI is superior in most cases, esp with a turbo, but just wondering if there are any specifics).
1 Post
No 1/4 passes on it yet. Once tuned hes hoping for somewhere in the 10s on pump gas and 8lbs boost, if the tranny will hold. Technically with the combo he has it will have the ability to push upwards of 800rwhp but that would be kinda useless on the street . The block/heads are o-ringed so he could go for 20+lbs if he wanted to , kinda nuts
Yup your correct about the carb. He ran it like that 2 summers ago. I think he just wanted something more tuneable with better driveability also. He got it to run fairly good with the old Carb but it still wasnt dead nuts on. Hopefully with the FAST setup and some knowledge from others in the area who have used it, it should be a good running car.
while i know that the FI is the way most people go, i don't know that it's necessarily more tunable. i'll be running a blow through carb on my setup. but if you look at some of the fast drag radial turbo guys, the are using carbs.
regardless, the car looks absolutely sick! and it's great to see your photography skills gettin' put back to use! any new times on your car since you've put the taller gears in it?
Car: 91 Camaro RS
Engine: TBI
NASTY, i love it....the headers going towards the front is what i love to see....i hope to run some nice lil power adders sometime soon.......Unreal, it is gorgeous....
COTM Editor
Sweet ride. I bet that car sounds sweet with boost, and nice and mellow for the people who don't know at idle. I love those flames!
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
love the flames under the hood. thats one hell of a car man.
Car: 85 Z28, 88 GTA, 68 Cutlass S
Engine: 305TPI X2 ;), Chevy 250
Transmission: T5, 700R4, powerslide >:(
Axle/Gears: posi, and posi w/discs :D.
all i have to say is wow.
thats freakin awesome. i think twin turbo setups are rad. how long has he been building this thing?
i dig the hood too, its nice to see somethng different that looks good.
1 Post
Yeah my car ran 13.6's after the gears. Just my luck. I cut better 60 foots but i cant come out of the hole full-bore anymore, it spins a little bit.
Purple Z28 - hes been building it for about 5-6 years now, everything from the stock 305, to a n/a 383, then the first twin turbo setup 2 years ago... now to this.
Car: 1992 Camaro 5.7L Z28
Engine: L98, G92 option
Transmission: Pro-Built 700R4
Unreal!! That is amazing. The only thing I would add to that car is a set of clear lights and some 5% tint. It may also look good to paint the t-top trim to match the car...
Any more pics by the way?
Car: 1982 Camaro Z28
Axle/Gears: 10 bolt auburn posi 3.73
1 Post
The windows will have tint on them asap, they are all new so they are just the bare glass right now. Should look really sharp
The door handles are out of a Geo Prism, and lined up perfectly with the stock rods. pretty cool huh
Clear marker lights will be next appearance wise. Hopefully i can get some more pics soon of the true dual setup underneath the car. Heres a few more...
its kinda strange to me that he chose a t-top car to throw so much power into.
1 Post
Ehhh... if i showed u guys some pics of the cage, it really woudlnt matter anyways hahaha. its kind of "excessive"
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
is he going to put some sort of grill on it, or leave it open?? just curious, where I live that rad/intercooler would be loaded with bugs in no time flat.
I'm not crazy about the hood, but that car is schwing!
Car: 1991 Camaro RS
Engine: 357cid
Transmission: T5 Swap
Axle/Gears: 10bolt 7.5" 3.23 soon to be 3.73
- Currie 9" rear
- Currie 9" rear
1 Post
Originally Posted by Steve383
I want a high rez of this...
I love this car
I love this car
The headers were custom made by our friend Matt (bottledbird68 on the boards). As far as a grill i think something will be done, but wont restrict any airflow to the intercooler.
one of those metal/billet grillz would look good IMO.
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: A/T
Car: 91 formula
Transmission: t5
Originally Posted by Vaneat-91RS
Do you know what year prism? I looked and not all the handles for those are the same....its a good looking mod.
94-97 style
yea those door handles are perfect!! now if only someone could find a nice set of mirrors to compliment and modernize our style of cars.
Car: 87 GTA
IMHO, the lines of those handles don't match very well.
I used C/K series '88-'96(?) Chevy/GMC truck handles.
You can barely make them out in this pic.
Also shaved the antenna and nose emblem.
yeah, but no handles don't work on a car that has to pass tech inspection at the drag strip. in the unfortunate event that you get into an incident, the safety crew needs to be able to get into the car.
mine are fourth gen handles and are a really good swap for those wanting something a bit different, but don't want to go through the hassle of putting in full out flush handles. the fourth gens are smooth instead of having that indentation on the thirdgens, and are a direct bolt on swap. here is a picture of the back wheels when i first got them, but the handles are in the pic too.
Originally Posted by brewersprts
I prefer no door handles.
#42
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
bitching engine and drivetrain . I love it . I just cant stand the hood . Other than the hood scoop its awesome . totally awesome. If his trans doesnt hold up i remember reading in a hot rod a few months ago that their is a t56 that will hold 1000 hp . So their is a t56 that will do the job .
#43
1 Post
Car: 87 Vette
Engine: 355/195AFR/SR/219CAM/1.6
Transmission: TH700R4/Vigilante
Axle/Gears: D44/3.45
nice car but i think something its wrong on the nose,i mean the "gfx" part of the bumper,its more v shaped that usual
why ?
why ?
#46
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
#47
COTM Editor
Tunedport335's got the old style gfx, where the TT car has the 91-92 gfx. I also believe that it is because the grill is missing that give the car that effect.
#48
1 Post
It does sag a little, i'm surprised noone noticed that the whole center-piece of the nose has been cut out to help airflow to the intercooler...but i'd say thats why it looks like that.
The mufflers are Borla XR1 race mufflers. The car is actually fairly quiet.
#49
Car: Faster
Engine: Than
Transmission: You!
Tell your friend to swap his bonnet out for an Extreme Velocity bonnet. We used a bonnet similar to your friend's current bonnet on my friends turbo mustang and it made 642 at the wheels. We switched to a E V bonnet and it put down 684 rwhp. It made a nice difference.
#50
Car: 1987 Camaro SC, 1999 Z28
Engine: GMPP 350HO, LS1
looks killer! would love to see a couple snaps of the exhaust setup.
