What to Strip wheels with? Nothing works!
Car: 1992 Camaro Z28
Engine: 406
Axle/Gears: 4.10 GM 7.5 10-bolt
I have set of 17" X 9.5" '92 Ronal Firehawk Rims. They are trimmed in bright red that looks tacky because it doesn't match my car. I want to repaint the trim black. I've tried the strongest stripper I could find and nothing takes of the red effectively. The clearcoat came off reasonably easy. The red, however, is either baked on or is a powder coating that refuses to cooperate. I've spent close to 20 hours on two rims and am only half way done. I've followed all of the instructions and let the stripper do its job for up to an hour. I don't want to sandblast them and ruin the machined finish on the face of the rim. Any suggestions? Anyone have Ronal centercaps?
1992 Camaro Z28; Engine:383 w/Edelbrock RPM ported heads. Lunati Solid Roller Cam 224/232 .502/.502, Fluidampr, 1.5 Roller rockers, 30 lb injectors. Haltech E6GM DFI, SLP 1 3/4" headers, 4" Mufflex, T56, 4.10. Super Ram.
Double-Pump This! EFI Rules!
Definition:
NOPI: n. 1. import 2. Sticker worth 47 hp 3. import with 6" exhaust tip
antonym: smallblock
Definition:
antonym: smallblock
Car: 1986 Trans Am
I used gasket remover to get rid of my clear coat, it was gone in a matter of seconds.
give that a try. If that doesnt work, just sand the red area, sounds like its a good base
1986 Black & Gold WS6
Trans AM...The Muscle Car Lives
...Its just not at home at the moment...
Nosaints Coolzone
[This message has been edited by nosaint (edited March 02, 2001).]
Nosaints Coolzone
Aircraft remover . try that.
If that doesnt work, you'll have to sand
91 Formula
305 TPI 5speed
1LE/G92/WS6
Paxton SN92 polished kit, SLP airfoil, ported/polished plenum, March pulleys, Crane AFPR(43psi),Crane Gold 1.6rrs,MSD coil,MSD6AL (5275rpm limit),Holley 9mm wires,Ac delco R43ts plugs,fastchip,Ford SVO 24# injectors,Bosch O2sensor,SLP 1 5/8" headers,SLP catback,shortened shifter,3:73s w/Auburn posi,170* t-stat,JET 195* fan switch, Macewen white face gauges, Autometer gauges, Zoom hi-performance clutch.
91 Formula
305 TPI 5speed
1LE/G92/WS6
As long as you're going to paint anyway, why bother removing the red? The red is obviously adhered to the aluminum very well, so it makes sense to just sand it and paint right over it. The new paint will adhere to the red much better than it will to the bare aluminum.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Tal-strip brand Aircraft paint remover. You'll find it at most autoparts stores. Be careful though, that sh*t is deadly, but it will even take off the powdercoated surfaces!
Hugger Orange '91 L98 Z
Engine: 406
Thanks guys. The red part is powdercoat and is extremely durable. I've called multiple refinishing places and they will not touch it. Everyone says, sandblast, sandblast, sandblast. I've used BIX Tough Job Remover, which is supposed to be an aircraft stripper. After three applications and a hour and a half, it barely softens it. I am going to get the rims repowdercoated when I finish the color change. However, the baking process will bubble any paint, so I have to powdercoat in a couple of layers. I am afraid that the softened powdercoat (from the stripper) may blister. What can I mask the wheels with to protect the machined finish while being sandblasted? Any other suggestions?
Definition:
antonym: smallblock
Definition:
antonym: smallblock
Actually I'm doing it right now. I have a set of new ZR-1's and they are powder coated black. I bought a can of JASCO paint stripper from a hardware store and used it on the powder coat with no luck. However I noticed if I put one coat on and put another coat on every 10-15 minutes for about 2 hours straight the powder coat was bubbling right off. You need to put a thick coat and wait it out. Dont let it touch the rubber or it will blister.
You'll need....
1. X-large can of paint stripper
2. cheap combonation size package paint brushes *will be thrown away after use*
3.I would recommend some rubber gloves because I burned my leg when I dropped it on my pants, and where did it go? straight through my pants
Be sure not to leave it on for too long without putting a new coat, dont let it sit for too long without rinsing with water also.
REMOVE WHEEL FROM CAR
if you strip the paint from your car, its not my fault because of my disclamer above
Have fun.
You'll need....
Have fun.
1992rs/ss
16
01-28-2016 09:58 PM
kah992
08-19-2015 02:55 PM
