Homemade Flame Throwers
Car: 1985 IROC
Engine: 350 TPI (block was swapped)
Transmission: 700r4 w/corvette servo
Axle/Gears: no idea
I ran accross this guide, Ill probably end up doing it to my camaro once I get it running
http://www.tnga.org/Tech/flame_throwers.htm
Car: 1999 Z28
Transmission: A4
I hope you like burned plastic bumpers.
IMO, flame throwers are cool on old mercs, buicks etc, but on a thirdgen, I am not a fan.
Car: 91 Camaro RS
Engine: TBI
Buddy of mine has a old skyliner, done up nasty nice he can roll about 15 feet of fire out the back but REALLY hard on the motor
Car: 85' Z28
Engine: 383 roller
Axle/Gears: Ford 9" 3.70
Yup, real stupid to do imho. We already get enough trouble from cops with a loud exhaust system, imagine what they would do if fire cam shooting outta it
Car: '91 Firebird Formula
Engine: 383 w/ BW S400 turbo
Transmission: TH400
Axle/Gears: QP 9", 35 spline, spool, 3.15:1
If you don't want huge flames, there's no need to cut the ignition or shut off the engine, just rev it a bit and you'll get enough unburnt fuel in the exhaust to make 1-3ft flames. It's easy to do. You can't do it with a cat though, of course.
Car: 83' Camaro
Engine: 355
Transmission: TH-350
Axle/Gears: Open...
1 Post
Car: 1988 trans am GTA
Engine: 350 tpi
your engine will be fine aslong as you change your oil each time you use your flame thrower.... your putting tons of gas through the engine and breaking down all the oil......... but flamethrowers are cool because nothing beats fire.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
Ive seen water do it a few times
Car: 1990 Camaro RS
Engine: 305 TBI (L03)
Transmission: 700R4 (MD8)
Axle/Gears: 2.73 Open (GU2)
Car: Camaro RS
Engine: TBI 5.0L
Transmission: 5-speed
Anywho, flame throwers are sweet. I'm gonna make my Camaro pop some little ones like bnoble's showin' for a lil' flash while drifting... Big *** 15ft flames are a bit much for a thirdgen tho, unless you have some laidout, crazy style goin on...
1 Post
Engine: 350 tpi
ive seen where people just use those small propane tanks and a coil sparkplug and switch so they dont so have to run any gas through the engine for fuel on the flamethrower. dont know how safe that is though.
Car: 1992 camaro rs T-top
Engine: 305 ci V8 TBI
I hope you guys know that raw fuel like that will melt your cat! but its cool with out cats and if you dont do it that much because that fuel will wash out your oil in your cylinders and cause problems with your rings. But fire just kicks *** and its better coming out of a Third gen!
Car: 1992 Camaro RS
Axle/Gears: Stock
Originally Posted by fitbmxseries1
good point..... but you cant really put water guns on a third gen.......
Anyway, The flames could look cool. But there are issues with the engine and bumper and whatnot. Doesn't someone sell a kit for that?
2012sergen11
10-13-2015 07:38 PM
