Opinion on painting engine block/head White
Car: 1986 Iroc-Z
Engine: 305 TPI (used to be Carb)
Opinion on painting engine block/head White - PICS of WHITE Painted Block!
Take a look at where I am currently at on my rebuild. I have a white Iroc and was thinking of painting the block and heads white, take a look and give me your opinion please.
Car: '92 Toyota Pickup
Engine: 22R-E
Transmission: 5sp Manual
Axle/Gears: 4:??
It would make your setup look unbelievably clean. Those new valve covers, new aluminum base, and a white painted block and heads would make that motor look great. Looks great already.
1 Post
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
i would vote to do it if money is of no concern.
1 Post
it wouldnt be as bad as black though. i remember this one time on here, this guy painted the entire thing this cast iron color, it was like a flat silver, and it looked really awesome.
Car: 1992 Camaro RS
Axle/Gears: Stock
The white would look good, and it would definitely be something different. But like the others said, it's gonna be hard to keep clean. But then, this doesn't look like your daily driver.
Engine: Cammed 6.0L LSX
i think it would be cool and really hard to keep clean, but i also think that a black block with red heads would look killer to offset the white engine bay
1 Post
it was cast aluminum by the way, and it looks awesome. the pic was removed though.
Car: 1985 Trans Am
Axle/Gears: 3.70
It won't be that bad to keep clean. In some ways it will be better. White doesn't show waterspots like black does. You'll also easily see where/if any leaks occur.
Only real downside is if anything is sprayed on it that eats paint, you'll notice it alot easier then say black.
Car: 1986 Iroc-Z
It is pretty much a daily driver. If I do the block and heads in White what color should the water pump be done in. The serpentine brackets will be aluminum in color like the intake has been redone to. I appreciate all the great comments and look forward to a few others.
1 Post
with white, i would make all the accesories the aluminum color.
Engine: 22R-E
Axle/Gears: 4:??
Originally posted by 1983Fbody
I think it would look good and I can't recall ever seeing an engine painted white before.
Car: 1986 Iroc-Z
Here are some pics. I only painted 1/2 the engine so far to make sure it isn't Fugly! Here are some pics
Here is one that shows with factory valve cover on right side and now paint.
Nothing is bolted together and the timing chain cover and pan are still loose. Still test fitting everything.
Let me know what you think.
Tony
Tony
Car: Pair of 92 Z28s
that looks great, way to be different
Just my original reply would have been the whole keeping it clean deal...but just see how it goes. Let us know how the white paint holds up to all the dirt/grime.
