GTA wheels on IROC...4 fronts or 2 front & 2 rear...
I may buy GTA wheels for my car this spring. I really like the way the black ones look. I have heard they are lighter than the IROC wheels, is that true, not that it matters? If I bought four with no offset(fronts) how do you think they'll look? Wouldn't that give me a little more clearance in the back for wider tires? Will they stick out too far? Anyone have pictures? I guess they'll stick out 16mm(~5/8") farther on each side but I would like to see or hear how it looks first.
350 Vortec, forged flat-tops, CompCams XE268, Edlebrock RPM, Holley 3310, TH350 w/Holeshot 2400, 3.23 posi, Heddman shorties, HEI
Car: 89 Camaro RS Convertible
Transmission: NWC T-5
I used to own an 87 GTA and you couldn't change the rims around b/c the backspacing is different. The back rims are smaller than the front so you can't put two sets of fronts on your car. That was what I was told by my mechanic who works constantly on F-bodies, although he may be wrong.
1989 Camaro Convertible
dark silver w/black top
305tbi, auto, all stock
posi
Check out Phil's Rice Boy Page
posi
If you put the rears on the front the tierods will rub the inside lip of the wheel making an unpleasant grinding noise and it'll knock off any wheel weights.
Drew
The lone Thirdgenner of the Apocalypse
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3@98mph
91 RS Convertible
91 Firebird V6FOR SALE!
92 S10FOR SALE!
98 Grand Am GT
Drew
My Website
87 Iroc
91 RS Convertible
92 S10FOR SALE!
98 Grand Am GT
i would think that u could put 4 fronts on it , because my freind had a 86 Monte SS and he put on Iroc wheels, and to make them fit he had to use 4 fronts, now this is a g-body, but they have the same brake setup so i would think they would fit.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Car: 87 Trans Am
Transmission: TKO 600
I have ARE 16x8's on my car and they all have the same off set. I believe there the same offset as the front GTA wheels. Don't Iroc's have front and rear wheels too? You could just try out your front wheels on the back of your car to see if they fit.
Later
Frank
[This message has been edited by Frank 84 Bird (edited February 09, 2001).]
Later
Frank
Hey all,
I just put on a set black GTA wheels on my car. The previous owner had the 89-90 IROC wheels on it. The GTA wheels are A LOT lighter than the IROC wheels. It does make a difference in aceleration. The engine has less mass to spin. IROC wheels have front and rears also. As for putting all four fronts on your car, I'm not sure. How big of a tire are you going to need? I have 245/50/16s all the way around. You could get 255s, but I would think if you want bigger for drag racing, then is a GTA wheel ideal for that?
John
John
When I had my stock Forebird wheels, I ran four fronts and the handling was quite a bit better. The look of the wider offset in the rear looked much more aggressive. Id say run the GTA wheels, but definetly run four fronts.
LS1 Killer!
Jeremy
1989 Firebird Formula L98 350
BBK 52mm TB
Edelbrock headers and 3" Cat-back Flowmaster
K&N cone filter
Free mods
MSD/Taylor ignition
Jet AFPR
150 shot NOS
Kenny Brown subframes
Hotchkis lower control arms, panhard and strut tower brace.
Eibach Pro-kit springs
Polygraphie bushings
Monroe SensoTrac shocks/struts
12.63@109.95 NOS
14.40@95.28 motor
L98Formula@yahoo.com
LS1 Killer!
Jeremy
BBK 52mm TB
K&N cone filter
Free mods
MSD/Taylor ignition
Jet AFPR
150 shot NOS
12.63@109.95 NOS
14.40@95.28 motor
ambainb
04-25-2016 09:21 PM
