pro-kit...sportline fbodies
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
man, there is tons of pics..
let me help you out a bit. Here is one of my '88 IROC's with sportlines.
Trust me.. its low.. too low for my preferences. Anyone want to trade me for a Pro-kit set? I just had these installed.. like 10 days ago.
Check out the front air dam and mud flap.., they're literally in the weeds!!
Car: too many ...
Here's my 91Z28 back when it had Sportlines and 17's. Dont have any pics of my old B4C with the Prokit, maybe I'll get some of my new B4C w/ Prokit whenever I get around to swapping the springs.
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
here's my prokit...which still has a ridiculously larger rake than any other pro-kit Ive seen...nonetheless I love it now.....and brisk if I wasnt so hesitant about ever doing a spring swap again I'd hit you up, I have less than 100 miles on mine
Car: too many ...
Maybe they goofed up and gave you Sportline fronts and Prokit rears? I think both fronts on either kit is a 700# linear spring, only difference being ride height. I dont remember any of my cars with either kit having that much of a rake. And when I look at the front in that picture you just posted, it looks like a Sportline drop, maybe its the 18's playing mind games with me. Compared to the pic of my car above, your front looks much lower even though it should sit about .8 inches higher than mine according to the advertised drops. Makes my car in the pic above look like a 4x4, though I think the angle of the picture of my car throws the look off.
no, it really sits low....too low for a prokit (my front tires basically are hidden by the fender)....but IIRC sportlines are colored red.....all 4 of my springs were black = prokit.....unless they painted them one color by accident and I got a 'goof up kit'......I did also rotate the rear springs a few times (though I didnt think they had a designated index)....when no drop occurred I put them back to the spot the stock ones faced, so Im out of ideas on it
Car: too many ...
Hmmm my Sportline front spring is black, but according to the markings on the spring its a Sportline spring. Weird. I even put it up next to a Prokit spring and they're exactly the same height uncompressed, just marked differently on the spring. Very hard to tell the difference if not for the markings. Of course its also possible the Eibach guy was wrong or my springs have the wrong markings, or wrong color. Guy didnt sound like he really knew, just reading from a book or something.
my sportline springs are red, all four of them.
Car: 2002 SS
Engine: Ls1
Axle/Gears: 3:42 posi
camaroguy18, no offense but that stance looks like poop. You need to get that rear down asap and the cars stance would be soo much better.
thanks for the input, but its staying
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
Originally posted by casebaseball205
any firebirds with GTA wheels lowered with either kit?
Brisk,
Your car isn't too low, your weeds are too high
-Schultzy
Car: 2002 SS
Engine: Ls1
ahh no come on , it looks like someone pulled out infront of you and you slammed the brakes goin 50. But its what you like, catch ya later.
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Here's mine, pro-kit.. 18's in the rear 17's in the front.. After seeing the sport line pics in here I'm glad I went with the pro-kit.. My loudmouth already sits like 2-3" from the ground as it is.. sport lines defintely look nicer though..
Car: 86 WS6 Trans AM/ 95 Trans Am
Engine: 305/Lt1
Transmission: 700r4 / 4L60
Axle/Gears: ? / 3:23
[QUOTE]Originally posted by CrazyHawaiian
[B]Hmmm my Sportline front spring is black, but according to the markings on the spring its a Sportline spring.
So wich one's are black? I have a set that I bought used and Im not sure wich set I have. Also where do I find the marking's?
Thanks Mike Fitz
Thanks Mike Fitz
Car: 1988 Trans Am GTA
Engine: 383
My car with sportlines and KYB shocks ans struts. She is low, my exhaust touches in places!
BTW, my buddies '95 Z28 also has sportlines in her.
Car: too many ...
The markings are on the springs themselves, on the outside of a coil, somewhere in the middle of the spring. There will be two markings, one xx/xx and the other one xxxx.xxx The first two have something to do with the rates, the second something to do with the model/part. If you have any doubt I would get the #'s off the spring and call Eibach. I dont think its safe to assume any black spring from Eibach is a pro-kit. I have a set of black springs and according to the markings and the guy at Eibach I spoke to on the phone, it's a sportline set (he didnt mention anything about color).
EDIT: I'm gonna give them a call again and make sure since everyone says the color determines what spring it is not so much the numbers on the spring (which I trust more).
86White_T/A305
09-21-2015 05:28 PM
