Best way to strip metal
Car: 82 White Stock Camaro
Engine: 2.5 151 TBI
Transmission: 4 Speed Manual
Try a blow torch, if that doesn't work try a hammer and a chisel, if still that doesn't work dip it in an acid bath.
Jk, What and where are you trying to remove the paint from? Airline stripper works good, so does some light sand blasting.
Lawrence
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Lawrence
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 89 IROC - 85 Z28
Engine: 350 / 305
Transmission: 700R4 / T5
Axle/Gears: Stock
Media blasting will take off anything and everything. There are different materials you can use depending on what the surface is. Acid works but can cause some problems if you don't flush the surface completely getting it out of all the nooks and crannys. You need to determine what exactly you are trying to accomplish and match that with the proper removal material and or device.
Car: 1992 Camaro RS
Axle/Gears: Stock
I was reading Chevy High Performance the other day and they "sand blasted" a 69 Camaro with baking soda, they said the baking soda also protected the bare metal from corroding, but you have to clean it before you can paint or anything.
That's just my
That's just my
![my 2 cents](https://www.thirdgen.org/forums/images/smilies/twocents.gif)
1 Post
Car: 78' Corvette
Engine: 383
Transmission: TH350
That's just my
That's just my
Car: 1992 Camaro RS
Axle/Gears: Stock
Originally posted by Draven
yea but if theres any body work that has been done, wont that mess it up, or no?
1 Post
Car: 89 Formula Firebird
Engine: 305 - Demon 525
Lawrence
Lawrence
sjorgens
10-01-2015 07:54 PM
