Before & After: My new 17x11 ZR1 Wheels! (56k Beware)
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
Greetings!
After 9 months of waiting, I finally purchased and installed my adapters, wheels and tires! I think that the car looks 1000% better than it did before.
The funny part is that I was expecting to have to "massage" the inner fender wheel to make those the 11" wide wheels fit, but it actually required very little adjustment.
Front: 17x9.5 ZR1, wrapped with Kumho low profile 275's
Rear: 17x11 ZR1, wrapped with BFG 315 drag radials
Let me know what you guys think.
HERE IS THE CAR BEFORE (2003):
![](http://www.patdesiato.com/DCP_1912.JPG)
Car: 1992 Pontiac GTA
Engine: 305TPI
Axle/Gears: 10-bolt, 2.73
Geez! What ever happened to the 3 pictures per thread rule?
How far do the rear wheels stick past the fender lip?
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
are you sure those are 245s on a 9.5 wheel , do you mean 275 . And the rears are wide as hell but they stick out way too far for my liking , they need to go in about an inch .
Car: 1995 Formula/2001 GTP
Engine: 5.7 LT1/3.8 Supercharged
Anyways...car looks good but I think the rears stick out a bit too much....jmo. Looks awesome otherwise
Car: 1986 Camaro SC (Supercool)
Engine: one composed of various metals
I agree with 18inchboyds....they stick out way too far for my liking...nonetheless I love how wide they are
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
looks pretty hot.
what size spacer you use on the rear?
A wider spacer will make it easier to install fat tires, but also makes it stick out a tad much like it is on your car.
Looks like you have the shallow 11" rim with a 2" spacer.
Sure a different look. I like the car either way too. I sort of like a little more sidewall maybe but that's just me I guess. Sharp car!
Engine: 5.0L TPI
Axle/Gears: 3.08
275's in the front.
Thanks for all the compliments guys.
The rear tires stick out about 1/4" on each side with the 2" rear adapter. The company that I ordered the adapters from (skulte performance) would have exchanged them for free, but since I am putting in a 383 soon and buying a new rear end, I will just order one that's a quarter inch shorter than the adapters on each side.
Skulte Performance did an awesome job on the adapters and was very helpful on the phone. Their customer service is clearly top-notch, and I would recomend them to anyone who's going to need adapters. Check out their site at www.skulte.com
Now that I have all these new pictures, I need to get someone to make me a new sig!
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
Car: 1987 Iroc-Z
Engine: 355
Transmission: 700r4 w/ about 7500 miles on rebuild
Re: Before & After: My new 17x11 ZR1 Wheels! (56k Beware)
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
Looking great tho man, glad to see u went through with it!
Car: 1989 Chevrolet Camaro
Axle/Gears: 2000 rear, 3.73, auburn locker
EDIT: Has anyone had or heard of a problem with the spacers breaking wheel studs like mine?
Car: 1987 Iroc-Z
Engine: 355
that wouldnt fix his problem. if the tires stick out 1/4" too far on 2" adapters, a 4th gen rearend would end with the same results.. ie, 4th gen rears are a total of 4" (IIRC) inches wider than 3rd gen rears (2" per side for those of you without calculators
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
![Confused](https://www.thirdgen.org/forums/images/smilies/confused.gif)
Car: 1987 Iroc-Z
Engine: 355
hehe, everything i can remember is that its 4" wider.. lol, measure, would be good to know for sure
Engine: 5.0L TPI
Axle/Gears: 3.08
Originally posted by LT1powered89
I would suggest you order a wider rear end and not use adapters. I have only had my wheels on for a few months and have broken 2 wheel studs that hold the spacer on the hub. Both where after a trip to the drag strip. All other lugs where as tight as they could get but for some reason the studs broke. Everyone I have talked to has said it was most likely because of the spacers. Since your getting a new rear end, get one for a 93-97 F-body. You shouldn't have to use spacers.
I would order a rear end that is a total of 3.5" inches wider.
Engine: 5.0L TPI
Axle/Gears: 3.08
Originally posted by Borsty
your old rims/tires for sale?
Engine: 5.0L TPI
Axle/Gears: 3.08
yea im in wny so your not that far away.
shoot me an email with a price
Car: 1987 Iroc-Z
Engine: 355
Originally posted by Sir Speed A Lot
too ****ing wide
too ****ing wide
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Time for a adjustable PHR. I put 11 zr1's on my 4th gen and it was off side-to-side. An adjustable PHR will correct that as you can adjust the lateral position of the rear.
I would go with a 1.5" spacer in the rear, I run those on my thirdgen with 285's and it tucks in perfect.
2" is great for the front, but a little too much for the rear IMHO.
![thumbs up](https://www.thirdgen.org/forums/images/smilies/thumbsup.gif)
Car: 1989 Firebird Formula 350
Engine: 5.7L TPI
Axle/Gears: Borg Warner 3.27
I agree that the rear tires stick out a little too far, but over all what a great look! Camaros should have come stock with wheels that size and style!
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
The only thing I would change besides tucking them under a bit would be black rims on your car. Would have gone really well with the stripes and headlight covers. Still really nice though!
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
not for nothing but i am runnign the same set up on mine. 17x11 with 315 drag radials w=using a 2" adapter. i dont know if you have gotten on the car yet but if you do you will notice that you are going to have to roll the fender lips. it starts to rub against the lip and starts cutting into the tires. my ride looks the same from the rear as yours does. like the way it sitsbut roll the lips
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Will definately be better when you get those wheels tucked in - here are the 17x11's tucked in on my car -
http://gallery.ss-perf.com/album08/DSCN2084a
my massaging to get them fit in nice... lol... its a LOT more than it looks!
http://gallery.ss-perf.com/album08/fls_065
either way - car looks 20x better
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: '02 Z06
Engine: 5.0L TPI
Axle/Gears: 3.08
I was thinking about heating the metal with a torch first... but that scares me on the driver's side because of the fuel tank..
How did you all do it?
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Hey man. Check out my site. If you are wondering how to tuck 315's, try 335's. I am not done yet, but if you wanna see how far they stick out now, I have a ton of pics. I cut the ribbed area out. And am gonna do a lot more. Keep trying, you will get them in.
Oh and in my opinion they look tucked to me. All good, don't listen to people that say they stick out a mile. Maybe 1/4" too far, MAX. and that is nothin. People relax, we are trying to stuff MASSIVE tires under these cars.
Originally posted by Gr89RS
Nice job on the tucking, got any better shots of them on the car?
thats where all the pics of it are... just click the 2005 category - plenty of pics in there
the best way i found was to just keep working them in with a hammer... some strategic shots and some heat into where the frame is in the front of the wheel well will do the trick - but pull up the carpet in that area - the heat will get in there...
Car: transam, el camino
Engine: 415
I would suggest you order a wider rear end and not use adapters. yep, good advise!
I think someone over tightened the lugnuts and stressed the studs the ONLY time I've seen studs break is after someone uses an impact gun to torque them down or they are extremely rusted. Factory torque specs for our cars is 100ft.lb. I'd never exceed 120ft.lb. even on a race application. Most impact air guns will crank out around 400ft.lb. I think this is what happened with yours.
#42
opps i didnt know i was suppose to torque down the lugs. i thought they were supose to be finger tite
yea if a tire place used a air gun that may well be your problem for breaking the studs. and btw i was kidding about the finger tight
#43
#44
while i do have a good gun, i just set it to about 150 and put em on - haven't had any issues myself....
on the other hand - i think i put the lugs on tighter when i do it by hand... the gun has toruble getting them off lol
#45
Car: 1991 Z28
Engine: 383
Axle/Gears: 3.08 10 Bolt
that looks sick...i want a set but a slightly smaller spacer so i can tuck my tires out back.
why do your rims look like they have a much bigger dish than other zr1's like ES87iroc's??
#46
Engine: 5.7L TPI
Axle/Gears: 3.42:1
#48
1 Post
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Looks great! I love 17x11 ZR1's on 3rd gen camaros! Here's my GTA with 17x11, 315 BFG DR's, and a 4th gen moser 9"... no spacers... they sit just right... they could go in about 1" if I could get them there....
![](http://www.team3rdgen.com/albums/album06/PDR_0127.sized.jpg)
![](http://www.team3rdgen.com/albums/album06/PDR_0122.sized.jpg)
#50
I'm thinking of swapping in a 4thgen rear. Seems to me I don't need spacers to run these rims with that rear, correct?
Btw, awesome car GTA91, please send some photo's of you're car or pics of swapping that rear in there to my email please. Thanks!
Speed_Demon440@hotmail.com
