Paint cure time, clear coat ?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
I am getting ready to paint my car with PPG Acrylic Urethane paint.
I will be spraying a clear coat over this also.
Does the acrylic paint need to cure before the clear is sprayed? If so, who long?
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
yes it does need to cure, you should have tech sheets with your paints read em all good and it will give you all those improtant times and mix ratios
jeff
jeff
Yea i'm in the process of painting mine and you should've got tech sheets for all primer, sealer, paint, and clear. If not i would try to pic them up they are very useful. They tell you the pot life and recommended time between cotes as well as recommended cure time.
Car: 1971 Camaro
Engine: 427
Well, I bought the paint at a shop that quit carring the line, so they did not have any info, tech sheets on the paint.
I am not doing the painting, just trying to figure out all this before it gets done.
1 Post
Engine: 305 tpi LB9
http://www.ppg.com/cr-refinish/phase1/frmHome.asp
here ya go ppg for tech sheets search by product name.
jeff
jeff
Car: 1971 Camaro
Engine: 427
Thanks!
I had been there, but didn't see what I was looking for, the good ol' search button sure helped!
1 Post
Engine: 305 tpi LB9
i could of gotten the sheets for you but did not know exactly which product line you had. i used omni so i had the link.
make sure you have a respirator for that stuff when you spray it.
jeff
jeff
ElPaleterro85
08-13-2015 03:49 PM
NBrehm
08-05-2015 07:57 PM
