finish film,sure finish and some nxt tech wax
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
spent the better part of the afternoon in the garage putting the finishing film to the candy. i got the finishing film from len at autobodystore.com. i also got a nice airvantage da sander to use it on and the interferance pad. i will never go back to wet sanding after using this stuff. man it makes short work of the sanding.
next was the sure finish polish and the mikita buffer and a wool pad, then more sure finish with a lose wool pad they sent me to try out. what an incredable diffrence it all made.
lastly was a quick coat on NXT tech wax. gotta love how easy it is to use and it smells good too.
1/2 the car is done other 1/2 next week.
jeff
jeff
1 Post
Engine: 305 tpi LB9
yes that last pic was in the reflection on the door
heres one last one, these pics taken without flash, hard to get the true look of the candy.
jeff
jeff
1 Post
Engine: 305 tpi LB9
finish film is made by 3m and is used on a d/a with a real short throw. and used dry, works nice.
Car: 87 Z-28
Engine: A worn-out 305
Transmission: T-5, until it dies
Outstanding looking ride, would like to see more....
BTW, do you mask off your hood louvers while buffing? My factory
finish is good (not as nice as yours, obviously) but for a daily driver
it's serviceable, but whoever buffed it out before I bought it hazed
the louvers , and I don't want to repeat that.....
1 Post
Engine: 305 tpi LB9
jeff
Pac J
05-17-2020 10:44 AM
