Wanted: Pics of all different size 16 inch tires on pontiacs!!!!!
Car: '81 Trans Am
Engine: 6.6L
Transmission: auto 350
hi i just piicked up a set of 16inch wheels for my firebird i think im going to make a trans am replica with now. And i want to see the difference buy looks when runing 215/60/16 compared to 245/50/16 and any other size combos out there only in 16" tho.
Please post pics of 215 and 245 and different series so i can judge on what i should put on for rubber. Keep in mind 215/60/16 are alot cheaper as i think i can find used and i know there is no used 245/50/16 anywere so its only new and thats too much $$ right now.
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
This is a Kumho 711 in the 245/50/16 size
Same size tire but different brand, can't remember what brand, same 88 Formula as above,
245/50/16 Eagle GSC's on my 88 Formula,
Toyo Proxie Z1 255/50/16 on my 16" GTA wheels on my 86 Trans Am,
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
here are pics of 215/55/16's on the back of my car. I had these tires mounted on a spare set of wheels simply to waste away (they were used). let me tell you first hand, the tires are SIGNIFICANTLY more narrow from the back, compared to the 245's (that's my car in 82firebirdta's post). my pics aren't the best at conveying this, but trust me.. from the rear view, its as if i went back to the base firebird 15x7's that my car originally had. GET 245'S... that is all
Car: 1983 WS-6 Trans Am
Engine: 1999 L31 5.7 Vortec
Transmission: 5 speed
Axle/Gears: Auburn Limited-slip w/3:73 gears
I have 245/50/16 fronts, and 255/50/16 rears.
Car: '81 Trans Am
Engine: 6.6L
ok got the idea of the 245/50's
does anyone else run 60's??????
My buddy actually has a set of 225/60/16s sitting in his basment i may beable to work a deal for.
Car: 88 GTA Notchback
Engine: Edelbrock'd 5.7L TPI
Transmission: Stage 2 Trans go 700R4
Axle/Gears: 3.27 9 Bolt BW
I use Cooper ZPTs on mine.
As for the 225/60/16's avoid em, They are too tall for the front wheel wells and you will get some serious rubbing if you do any sort of sharp turning, especially during parking. I bought my car with em on there and they are just too tall for the wheel wells, I had to replace the wheel well covers because they were almost worn through from tire rubbing. Also screwed up the alignment as well.
Car: '81 Trans Am
Engine: 6.6L
you think they will rub on my firebird... I think the springs are a bit different as mine sits pretty high... im sure its higher then your ta.....
take a look....
theres 70series 15" on there now and i was thinking even a 225/60/16 may be abit better an actually smaller around. maybe not... mmm does anyone have a good tire caculator that can figure out diameter or circumferance sizes by imputing the tire sizes?? Id like to figure our how much more all the way around a 225/60/16 is larger then a 245/50/16 cause you wouldnt think it was too much more.
take a look....
http://www.1010tires.com/TireSizeCalculator.asp
Thats the tire size calculator I use...
215/60/16's are about .6" taller than 245/50/16's and skinner by 1.2"
225/60/16's are about 1" taller than 245/50/16's and skinner by about .6" as well
Even the 245/50/16's still rub. I dont think it has to do with the height more so the width in my case. Measure it up and do the math. But 1 inch difference seems so minor but in my case it was like night and day with the different tires.
Car: '81 Trans Am
Engine: 6.6L
ok cool thanks for the info man i may tryem still not like im paying much for em and if they rub too bad i can put them my saturn its got 16s also.
colton_carlson
03-08-2019 12:21 PM
toronto formula
11-10-2015 06:17 AM
knight72
08-10-2015 09:32 PM
