Drag Radials on Irocs
Car: 86 Iroc-Z28
Engine: FB385
I did some searching but did not find exactly what I was looking for. A while back there was a member who had a black Iroc in a car port who had just gotten drag radials put on. Anyone remember this thread at all? Anyway, not sure if this is the right forum but I am looking for pics, and sizes of your drag radials on stock wheels(16x8s). I was thinking of 255-50-16s. Either the BFGs or Nittos 555r. I have a daily driver now so these tires would see maybe 250-500 miles a week, max. Absolutely no rain, only in certain circumstances(like when the weather report wasn't watched).Any help would be cool. thanks
Car: cleanest '86 sport coupe around!!
Engine: 355ci twin 66mm turbos on e85
Transmission: built rmvb th400 w/ t-brake
255/60/16 is the way to go for 16x8 rims...they will not stick out and at the small time they are not too narrow either if that makes sense.
I use Nitto DR's myself. The size for my stock 16X8 IROC rims are 245/50/16. They don't stick out at all. And 9 times out of 10, people that I would go street racing with didn't even know they were there. They fit very well and perform well too. Sorry I don't have any pics of just the tires.
Car: 86 Iroc-Z28
Engine: FB385
Thats why I would like to see some pictures. I know a lot of people who have done it, so they say, I just have not seen any pictures of them. The car I mentioned I believe had done this and that is why I would like to find his thread.
mw66nova, yeah I was thinking of buying a spair set of iroc wheels and putting the DRs on them, but people seem to be pleased with the amount of life they get of their tires. Trust me, the car will not be to a track very much.
Thanks for all the help guys. Anyone else?
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
My car doesn't see track time either, but I still need to look into DR's basically because regular street rubber, leaves my *** end all over the road even with regular to mild driving habits. I need the softer compound. Maybe he does as well.
Car: 1987 Camaro Z28 IROC-Z
Engine: 5.7L TPI
Axle/Gears: 3.42:1
Originally posted by 18inchboyds
how does a 255/50-16 fit . Does it look out of place compared to a 245 or is it not noticable.
Car: 1987 IROC, 1989 IROC
Engine: built 305, stock 305 tpi
Transmission: Corvette 700r4, t-5
Axle/Gears: 4.10 posi, 3.08 posi
What about mickey thompson Street E/T's?
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Actually MT makes a nice looking set of fully treaded DR's now.
Either that or a set of BFG's or Nitto 555r would be a good choice.
yeah, but they use the same compound on those dr's as they do with the street et's. they are SUPER soft. trust me, i am a huge fan of DR's. i hang out with all the DR guys from NSCA and BigDaddy's races as well as the orlando stuff. i know dr's pretty well. i also know that if you want something that will last but only hook quazi well, get the nitto 555's, but if you want ultimate hook get the m/t's but they don't last long on the street, and the bfg's fall somewhere in the middle with a little more emphasis on hook and a little less on tread life.
Car: 1992 Z28
Engine: Stock L98 with bolt ons.
Transmission: Stock rebuilt tranny with 2k stall and cooler.
Not exactly an IROC but they are 255/50/16 BFG drag radials mounted on 16x8 Prostar XPs. I never had any problem with them rubbing wheel well lips or anything and I've had the DRs mounted on stock wheels and 16" Snypers before this.
Car: 86 Iroc-Z28
Engine: FB385
Well the whole purpose is for better than avg traction on the street with not too much of a concern on tread life. Also, instead of purchasing track wheels(slicks and skinnies), I plan on using my stock wheels for now for track outtings and next year I am getting some 18" wheels with sticky tires. I see no need for super expensive tires at this time for the irocs. That is my point. I just got my car on the road and it is a brand new motor. I only ran it up to 4000rpms from a roll and broke traction like nobody's business(last time I did that). My 75% treaded BFG Comp T/As don't seem to cut it if I were to launch the car when it is broken in. If you can find me some sticky tires for the street for as much cash as DRs that serve the two purposes mentioned(street use/drag strip), let me know. I know that there are companies out there such as Perelli, Micheline(sp), ect, but they are expensive. Those tires will be purchased in the future for my "street"/cruising wheels. Make more sense now? Hard for me to explain I guess. I am not a *****-out racer that some people seem to be. Just want some nice tires that will serve my needs. thanks
Car: 86 Iroc-Z28
Engine: FB385
Thanks ThirdGenZ28 92, that is pretty much what I needed for the look puropse of this thread. Nice wheels. Any other pics, maybe of the whole car? Also, is that with your Pro Kit or different springs? thanks
well, the dr's work great on the street if you DON'T do a burnout. lit 'em up big time one time on the street trying to get them sticky, well, without the VHT on the track, it did the opposite. it made the tires slick. i did nothing but leave 330+ ft of posi tread on the street. just a tip if you do go with them....i think for your needs, i would suggest the nito 555's.
Car: 1992 Z28
Car: 1992 Z28
Those are 17" Snypers up front that's the reason for the car looking "off".
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
My BFG's hooked like a **** when i heated them up beyond belief. The balder they got, the better they got when heated.
330+ft?? wheres the pics??
hot rod magazine did a test comparing the new mickey thompson drag radials, with the ET streets, and when heated up, the Drag radials performed (on average) better than the ET streets!!!
my nearly bald street tires when hot turns to ice one the street, but at the track, they hooked pretty good. my new street tires also when heated dont hook real great on bare street, but do a quick burnout patch, and line up on it, the car takes off great!!! so maybe heated tires stick good when on rubbered prepared tracks
Car: 1992 Z28
I get plenty of hook with my BFG DRs. I heat them away from the water until I see smoke, hold it for a 3-4 count and roll out of it. If they prep right I'll see 1.7 60fts easy.
Car: 92 Firebird Formula
Transmission: 700 R4, 3.73 rear
What gear do you have? I have a 3.73 (soon to be switching to a 3.42) I and the best 60ft I ever got was a 1.88 due to a slight tire spin. (usually get a 1.95 or so) I'm switching gears because I'm trapping at 5000 rpm on my current setup but I was wondering if I would get better 60fts.
Hey thirdgenZ28, are those particular weld wheels a direct fit for the thirdgen or did you have to use spacers/adapters? I am thinking about getting a set for this coming season. Let me know and by the way, they look killer dude!!
Car: 1992 Z28
Ator....I'm running a stock rear with 3:23s.
Those wheels are direct bolt ons with no spacers. They are Pro Star XPs. They do require wheel specific lugs though. Thanks for the compliment!
Originally posted by Orr89RocZ
does a 255/50/r16 drag radial handle decent? not just for traction on the straightline but what about corners?
ThirdgenZ28, what is the part number for the welds exactly like yours? I can't seem to find them for some reason.
1 Post
Car: 92 Z28
Engine: Boosted LSX
if Rick head can run a 7.80 in the 1/4 on Drag Radials I think they are fine for anything else..lol..
Those Xps look good man. To bad they discontinued em for now.
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
i just bought these tires hopefully that last at least 20,000 miles but i doubt it. just for rear
Car: 87 Iroc Z
Engine: 383ci.
Transmission: WC-T5
Those look like the new MT DR's.
But they're right. Dr's don't last long. If it's a daily driver, expect to buy a set a year.
#44
Car: camaro...????
Engine: 305ci of mouse power
Transmission: 5 speeds of fury
it's not gong to come back down....its going to go up and up and up and up and then dissapear
#46
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
Two of my buddys went up there with smokey hall that car is simply badass i was in awe when they told me about it and it seems ive been beat to posting it. Oh BTW Who hold the two fastest times? Thats right two Thirdgens
#47
I was thinkin of goin with Nitto 555r's for the rear and the 555's for the front when my car was finished. It will be a summer only car with some shows and passes at the track. So you guys say its better not to do a burn out with them on the street?
555R
555
555R
555
#49
Car: 88 Iroc-Z L98
PROSTAR XP'S 17" WITH Nittos
Hey Guys,
I have had this setup on my car for about a year without a problem. Prostar XP 17 x 8 (front) & 17 x 9 (rear) nittos all around with Drag Radials in back. No rubbin problems. Clearance is very close.....
I will post pics if interested.
Rob
1EYEFUL
Rob
1EYEFUL
#50
COTM Editor
Received 1,890 Likes
Car: '89 Firebird
Engine: 7.0L
Street Lethal
04-30-2019 12:14 PM
mustangman65_79
08-11-2015 03:17 PM
