powder coating driveshaft ???????
Old 12-06-2004 | 09:26 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
Axle/Gears: 9", 3.50
Hi guys, I was about to powder coat my aluminum drive shaft and I noticed that the balancing weight has what looks like some kind of epoxy around it. Does anyone know what this is or if it will hold up to powder coating. Can I take off what's around the weight so i can coat it well? Thanks
Old 12-06-2004 | 09:30 PM
megaracerx's Avatar
wouldnt powder coating it make it heavier? that should throw it out a wack right?
Old 12-06-2004 | 09:39 PM
tojan19's Avatar
Car: 85 Tojan
Engine: ZZ4
I don't think it would make it much heavier. I'd bet it only takes a couple of ounces of powder if that. Probably less.
Old 12-06-2004 | 11:16 PM
MNformula350's Avatar
Car: 1990 Formula
Axle/Gears: 3:73 Posi
i am not sure what it is that holds the weight on but, why would you powder coat it? if you do i would take it to a driveline shop and have it balanced afterwords. you could just polish it.
Since it really isn't seen i just had mine balanced and i put it in the car.
Old 12-07-2004 | 02:17 AM
1320 Right Ln.'s Avatar
balancing of a driveshaft needs to be VERY precise. If you decide to powerder coat it, then it's imperative that you get it balanced afterwards. Practically anything you do to the driveshaft that alters weight, merits a re-balbance... i'd say the only exception would be if you clean it up n' lightly spray paint it.
Old 12-07-2004 | 11:53 AM
Dr G's Avatar
Re: powder coating driveshaft ???????
On searching I couldn't find anything about powdercoating aluminium driveshafts. Why do you wish to powdercoat it?
Theres plenty of info out there as regards polishing your driveshaft to a nice finish to enhance its appearance.
Here are some links to threads you may find helpful:-
Nice driveshaft
https://www.thirdgen.org/techbb2/sho...veshaft+polish
What should I use to polish my Aluminum Driveshaft
Aluminum driveshaft? which one?
Hope that helps you!
MoJoe
Members Camaros
31
10-06-2021 07:38 PM
cmichael
Exterior Parts for Sale
12-21-2015 07:56 PM
Cam-aro
Camaros Wanted
11-12-2015 04:35 PM
Bubbajones_ya
10-25-2015 09:01 PM
loud91rs
10-05-2015 11:05 PM
Quick Reply: powder coating driveshaft ???????
