Rhino lining the engine compartment
1 Post
Car: 00 Camaro SS
Engine: 5.7
Transmission: 6 speed
I am going to do a complete color change on my t/a this winter and I am thinking of using rhino lining(spray in truck bed liner) for the engine compartment because of the chemical resistants and sound deadening.Anyone ever do this?How did it look?
Car: 1992 Camaro RS AKA Big Nasty
Engine: Carbed '79 350 block, 360hp/380ftlbs (flywheel)
Transmission: 6speed from an unidentified 4th gen. ask me, ill tell you.
rhino lining would be pretty thick. I think it woulnt look correct either. Many people have used POR15 though which would do the same job. Maybe look into that..
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
how would you handle bolts? that rino lining is pretty tuff stuff if you put it over bolt i'm not to sure you would even be able to get the bolt loose after.
on another note if i was looking to buy a car and i seen rino lining in the engine bay i would pass on the car...defitanly not my taste. i would paint it. a good base clear will hold up just fine would look better matching the body of the car. put sound deadner in the interior and it will sound like a new car off the factory assembly line. i used brown bread and the door close with a solid thud no noise rattles or anythkng like it was originaly.
jeff
jeff
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
I would not do this. Rhino lining is heavy and would greatly affect the way stuff bolts down and the way the front end of your car handles. Whats wrong with paint? You can deaden the sound of your motor in much more effective ways.
Car: 2004 Pontiac GTO
Transmission: M12
LOL. I would love to see it. Please be sure to post pics if you do this.
edit: nvm, it would help if i read the entire thread.
Car: 89' RS
Engine: 5.0
Transmission: slipping 700r4, soon probuilt
www.por15.com read on that website about it. it tells you all you need to know about the stuff.
84z96L31vortec
08-20-2017 12:16 AM
theshackle
03-05-2017 06:37 PM
84z96L31vortec
08-10-2015 08:27 PM
