Finally Painted car and more
Car: 1987 IROC-Z
Engine: 305 LB9
Transmission: 5 Speed
Axle/Gears: 3.70 Posi BW 9 Bolt
I finally got around to painting my car and also painted my rims. This summer i swapped in
mild 350
Tci 700r4 kit
b&m shifter
Bmr relo brackets
got rid of a/c
fiberglass wing
Paint
plus lots of little things that add up to around $3000
mild 350
Tci 700r4 kit
b&m shifter
Bmr relo brackets
got rid of a/c
fiberglass wing
Paint
1 Post
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
way to go! What color is the paint, and are the ground effects black like i think you were talking about doing? It's really come a long way from when I saw it in person last year. Be sure to enjoy it before the winter hits.
Car: 1987 IROC-Z
Engine: 305 LB9
well this car doesnt matter any more i bent the frame today only damage was the rim and the cracked frame i hit a curb after the throttle got stuck but im going to find a nice rolling chasis to put all the parts in and paint it yellow and black this time.
Car: 1987 IROC-Z
Engine: 305 LB9
the k member is bent the front of the frame is cracked in 2 places the spring cup is bent about 3in up the control arm mounts are bent the motors a good bit crooked and wheel came back so hard its hitting the fender alot to where i cant even turn the wheel.
Car: 06 SRM M6 GTO, 98 Grand Prix GTP
Sounds like you might be able to get away with a k-member and the control arms. Its worth looking into I think. I got a k-member from Trans Am Creations...that plus my control arms, center link...various other things...plus 2 days work...I think I spent like
300 in parts...not including wheels and tires. I think its at least worth checking out rather than junking the car and starting over, especially since you got the new paint, plus all the other parts. Just my opinion.
Car: 1987 IROC-Z
Engine: 305 LB9
well heres what happen the upper spring cup is moved up the frame was smushed up but i cant figure out how the wheel is so far back its touching the back of the fender bad???
kah992
08-19-2015 02:55 PM
ElPaleterro85
08-13-2015 03:49 PM
