sandblasting rims
Car: 1987 Pontiac Firebird
Engine: 350 sbc
sandblasting rims
no idea where to put this but o well
is it ok to sandblast the stock formula firebird rims? or should i just take the time and wet sand them? or blast then wet sand? thanx in advance.
1 Post
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
depends on the look you want sand blasting will give a pitted look like rough cast very hard to shine after that. I would follow the tech article for polishing if you want a shine. if you are ainting them than sand blast should be ok.
Jeff
Jeff
Sandblasting will leave them very rough looking. I had a core support blasted and I couldn't believe how rough the metal was when I got it back. I would imagine aluminum wheels would be worse, as alum is softer.
If you do decide to sandblast the wheels, I'd paint them with several coats of clear afterwards. Otherwise, brake dust is going to be impossible to remove from all the little "pits"
Car: FBODYS
Engine: ALWAYS 8'S
Transmission: ALWAYS MENTAL
Axle/Gears: RUSTY AND BRAND NEW
The finish and pitting depends on the grit of blasting compound you use. For steel we use 40 grit. For aluminum we use 400 to start and 1000 to finish.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
