ZO6 rims!!!
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
ZO6 rims!!!
Ok guys, Im about to get some ZO6 rims. The fronts are 17"9.5 and the rear is 18"9.5. FOr the front can i run 245/40/17. will that look good and the back the samething. or do i need a wider tire and bigger profile???
Car: 87 Monte Carlo SS
Transmission: 200 4R
I would say at least 275s. I dont know how safe a 245 tire would be on such a wide rim. 275s wont even bulge out on a 9.5" wheel. I think you need some 315s in the back and 275 in the front. That would be bad ***.:hail:
Car: Camaro RS/SS
Engine: 5.7 LS1
yout think i should go 315 in the back and 275 in fornt. i was planing on going with 275 all around. Will the tire fit back there??? i think the most ill go with is 295 in the rear.
Car: Camaro RS/SS
Engine: 5.7 LS1
so will it look funny if i went with a bigger tire in the back than the front. I want to go with 295 in the back and 275 in the front for rubbing purpose. will that look ok or should i just keep the same tire all around????
Car: Camaro RS/SS
Engine: 5.7 LS1
Car: Camaro RS/SS
Engine: 5.7 LS1
you think that the rims size will look wired?? I dont think it will. it will give it that sporty look i think. the zo6's have the same combination. and they look sweet. and i know its a diff car but. oh well. thanks for the inputs guys.
so many cars on the internet with those wheels no need to photochop.
the picture above shows it all. it's like riding around with a 15" spare when you have 16's...your car though so go with it.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
