View Poll Results: Should I Get my car lowered? & How much of a drop?
Sport Lines: 2 inch drop
17
44.74%
Prokit: 1 inch drop
28.95%
Leave it alone...looks good
21.05%
Wait for airbags
5.26%
Voters: 38. You may not vote on this poll
The time has come....Should I get my car lowered?
Car: 1991 Z28 Camaro
Engine: 5.7
Axle/Gears: 3.23 For Now
Okay guys...
Do you guys think I should get my car lowered? I've narrowed it down to either the Sportlines: 2 inch drop-or-the Prokits:1 inch drop. What do you think?
Somebody modify that Thirdgen Modifications 101 Tech Article to include lowering springs........
Yes, you should lower your car, Airbags would be really cool, but can you justify that amount of money on it?
Engine: 5.7
I'm still not sure what I want to go with. If I could get an airbag system that would just lower and raise my car...that's all I would need.....nothing fancy. If I get the sportlines...I won't be able to adjust the ride height. Also, if I go with a set of lowering springs..I'l have to get my exhaust re-done. My McCord Power Plate and Cutout are pretty low to the ground as it is....if it was much lower...I would be hitting everything...
Car: 1989 Toyota Supra Turbo
Engine: 7M-GTE
Transmission: R154
Axle/Gears: 3.91 LSD
Leave it like it is man..
You car kicks *** :hail:
I don't think the TT2s would look good with the car lowered..
my
my
Do you need LCA relocation brackets after you lower? I could have swore I read something like that...
Ive been thinking of doing this myself. But I would also have problems with my exhaust too I believe.
Engine: 5.7
in this picture, you can tell how much lower his sits compared to mine..
Lowering - A must, how much - that depends.
I don't know how you drive or where you use your car, but my recommendation is to be safe and lower your car 1." I prefer a fixed height suspension, which is why I didn't vote for airbags.
Car: too many ...
I say it depends on why you want to lower it. Do you want the look or do you want the handling? If you want the look then Airbags would be the best choice, with Sportlines being second choice. If you want the performance then Prokit would be first with Sportlines being the second choice. (this is all just my opinion hehe). I wanted both and I'm a cheapazz so I'm running adjustable spring pertches with specific rate and length springs. Bags are nice if you can afford it, but definately go with the new Air Struts if you plan to drive hard.
If you COULD buy dropspindles around the corner, i'd say install them AND the eibach pro-kit. But you may have trouble finding some, so i say sportlines and cut off a coil or so. Because even with sportlines the car will have the truck-ish stance
Originally posted by 84customZ28
I don't believe you do...my brother has his 87 Z28 lowered with the sportlines...and he just had the springs installed...and that's it...nuttin else
Trust me......I know..........
Car: 91 Z28
Transmission: built 700R4
I seccond what flyinlow said, If you get sportlines, (wich you should) you need relocations brackets and LCAs and an adjustable panhard bar. I was hopping all over the place before I installed the Relocation brackets and LCAS in my Z
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
IROC,
Your exhaust clearance should be fine. If I recall you are not running lontubes. Your 2055's and 3" sytem will be okay.
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Yes, relocation brackets are bascially a must if you are going to do any racing or driving in the rain. They are a huge difference!!!
Originally posted by FLYNLOW92rs
LOL, unless you enjoy doing doughtnuts that look like this, I HIGHLY suggest new LCA's and relocation brackets for you car......
:yourock:
Engine: 5.7
I see what everyone is saying. But this is all for show, no racing and no hard driving at all. I drive my car how an old grandpa would
Eh for some reason, it is pretty low at one point after the cat. Is the LCA stuff hard to install?
1 Post
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
go with airbags..
yes they are more expensive, but in the long run they are better...
you can adjust your car to any type of terrain..
thats what im doing..
but my application is prolly different...my iroc is strictly show only
iroc2nv
iroc2nv
Engine: 5.7
Engine: 5.7
I just emailed Air Ride Technologies and asked them what I'm needing. If I go with an air ride system....I'm just wanting plain and simple....just to raise it...and lower it...nothing fancy. They are located in Jasper Indiana..and I'm from Central Indiana....so..I
Kandied.....wonder when he will chime in?
he got some BS from some clown on another thred so he's been lying low but i'm sure he'll turn up soon
please let us know what they say
Yeh you know it pisses me off when some1 complains now some1 that gives alot of valuable info was pissed off. I actually think he didnt show enough secrets about his car lol.
1 Post
Axle/Gears: 3.45
The front kit is part # 75516, The rear kit is part #75616. You will
also need a Air Management System, I suggest 27041AL. See Attached.
Thanks for your interest in the EasyStreet product line.
Jeff Appelgreen
1-800-248-0892 ext.243
www.easystreetair.com
www.airliftcompany.com
www.airliftco.com
"Redefining Air Suspension Performance"
i have the attatchments if you are interested...pm me with your email addy and i will send it to you man..
iroc2nv
1 Post
Axle/Gears: 3.45
and then i emailed one of their distributers....for installation and whatnot..
this is their email...
Gerry,
Air Lift Company's Easy Street has a system available for your car.
Complete kit with a FBSS compressor system with 75516 front kit, 75616
rear kit and 27541CD compressor system goes for $2564.00 and install
is
$950.00 base price.
Let me know if you have any questions.
Jeff Moak
Sales and Promotions
Altered Altitude Customs
2200 Markham Rd. Unit 6,
Toronto, Ontario
sales@alteredaltitudecustoms.com
416-396-3572
1-866-***-NLOW
iroc2nv
Gerry,
is
$950.00 base price.
Jeff Moak
Toronto, Ontario
416-396-3572
1-866-***-NLOW
iroc2nv
Engine: 5.7
Originally posted by Oddball
Dude, your car is beautiful as it is in the picture. Why f-with it?
that's what people said when it was stock too though...there is always room for modifications and improvements
if you want to be able to adjust the ride height, have you ever considered ground control's weight jacks? little cheaper then air ride, but not as easy to adjust
i have the prokit, and i really wish i i would have went with the weight jacks so i can adjust it. it almost needs to be another .5" lower and i would be happy. like you said, there is always room for improvements
here is a pic of my car with TT2's and the prokit....
Engine: 5.7
what are weight jacks? I'd like to know more about'em. I'm really just looking for something that will allow me to adjust the height of my car....if there are other options than airbags...that would be cool...even if it would be harder to adjust..
Engine: 5.7
I just dug this up too
Kandied posted this awhile ago in an older post...
"for those who don't want to do that and are looking for the cheapest way you just replace the springs with bags and call it a day."
I wonder what the price difference would be? I really wouldn't care if it would be harder to adjust....
i have seen jeff's system in person, it is a very sweet setup. but if you just replace the springs with bags, i believe you wont have the handling that you would with a system like jeff's. however, i dont know how much different it would be
ground control
there is ground controls website, its a lot cheaper, and i am still strongly thinking about getting them for my car. there are a few people that have them on this board.....
ground control
Engine: 5.7
ground control
ground control
On that site...what do I need to look at?
Ghettobird52
07-05-2024 11:18 PM
1992 Trans Am
05-10-2023 07:19 PM
NBrehm
08-25-2015 11:49 PM
Linson
08-21-2015 02:12 PM
