The "Badass" look
Car: 1991 Camaro *RIP* 1984 MonteCarloSS 1972 Nova
Engine: 355 cid 383 cid
Transmission: TH350 TH350
The "Badass" look
I was just wondering what tire size would give me the look im looking for you know the one im talknig about the hotrod tilted look i was thinking like 265/60/15 our back and 245/60/15 out front. do you think i could achive the look like that with draglites of corse.anyone have a setup like this or something like it? if you do can you please show me thanks
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
theres more then one way to get the "badass" look...
for example, some people thing 3" wide and 11" wide drag wheels look badass... meanwhile others think that 10" wide fronts, and 11" wide rears with it lowered to the ground look badass......
just do what you want and think looks nice... fug the others.
18 inches of rim isnt my bag man im kinda "old school" 15 inches mabey 16 max for me i think the whole small tire big rim thing is kinda lame but to each his own and i dont to lower the car anymore than it is cuase down here its a hazard being that low i mena it scrapes a bit much and that sound makes my heart cry anywho anybody got soem draglite pictures and tire sizes plz thanbks for the help guys but 18 is a bit much for this guy
Car: 85 firebird
Engine: Pos 2.8 pulled and replaced with a 350 tpi motor converted to carb.
Transmission: 700r4, vette servo,shift kit, hayden 15"x8" trans cooler.
Originally posted by IROCThe5.7L
:lala:
:lala:
That is badass! :hail:
Car: 1984 Z28
Engine: 5.7
Transmission: Auto w/ shift kit
Re: badass
Originally posted by knhghs
Another angle. Hail Graboid!!!:hail:
Car: NCC-1701-D (docked in AZ)
Engine: impulse drive
Transmission: fusion reactors
Axle/Gears: Rescued from the Borg by my crew
I have 275/60/15in the back and 235/60/15 in the front. It made the car look meaner in my opinion after I put on the 275's. Tires are wider and made the car sit up a little in the back.
Car: 1991 Camaro
Engine: 2000 LS1
Transmission: 4L60E SS3600
Re: The "Badass" look
Car: 1984 Z28
Engine: 5.7
Originally posted by CaysE
They're the Sport Coupe style taillights with the amber blacked out. You could tint it or just move the blinkers and paint it black.
Car: '85 Z28 Camaro
Originally posted by PhAnToMs
the amber orange part what does the light inside function as? cause that looks sweet and i have those tail lights but with the ugly orange in them
here is what i like, larger wheels so you can have larger brakes. yes you have to have thinner tires but the new dr's out now can hook better then some of the above that look like what was on the car. you get corner handling with a stiffer sidewall, great acceleration and grip for the straights and the large area for brakes with the updated look....
but it isn't for everyone.
Car: 1984 Z28
Engine: 5.7
Originally posted by JestahX
The light inside is the turn signal...i do believe you need those to be street legal. Unless you wired the lights to act as stop/turn signal lights.
just because you want wide tires doesn't mean you have to settle for having them stick outside of the car....
heres a rear shot of 295/35/18.
Kandied- I know you know the rules. This isn't the first or even third time I've removed images from your posts. Three uploaded images per thread means just that. You have a cardomain site, use it. Thanks.
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
295, how wide is that rim...can u squeeze that tire on a 9 or ten inch wheel....
Car: '89 Formula 350
Engine: 5.7L L98 TPI
Transmission: 700-R4 Automatic
Axle/Gears: 7.5 disc posi 3.23
Hey Candied.
What rims are those and what size specs? Are all the tires 295s?
Car: '86 iroc
Engine: lb9 305
Hey omnipotent, are those 17/18's a photoshop or real? If its real thats the first 17/18" combo that I've seen that doesnt look like crap, in fact it looks damn good
I have an eibach prokit on and even though it lowered an 1 or so, it has a little "rake" to it. the rear sits an inch higher than front. It still has 16x8 iroc rims on it with 245 tire. I personally like the even lowered look all the way around and would have liked an extra half inch lowered if possible but it is not very practical as scraping does occur underneath. It does make you shutter at the sound.
But the little rake in the stance looks "mean", "badass", etc.
That me but maybe you would like this. Found it on this site. Forget who it was though.
that picture with you always kills me.......
the only thing i don't like about the 17/18 is the fact that you almost have to "rake" the suspension to make the gaps even. the body wasn't designed for that type of setup so otherwise it looks funny when at certain angles and especially while rolling down the road.
Charged350, that's a 18x10" rear rim. yes you could squeeze it on a 9 i suppose although your ride will suffer. you should put the right size tire for the right rim and in that case your offset/backspacing if sat right should sit the same with any of the common wheel widths.
FIRECHICKEN if your asking about the last picture i posted those are the rims on my car now. boze stinger model and no it isn't 295 all around. i'm running 245/40/18 up front, it's pointless for a street car to have that wide of a tire up front and with how i like to lower the car it's impossible to run that wide upfront. you can get away with a 275 width and have some lowering but any wider and your asking for troubles.
for my setup i wanted the wheels and tires in the exact stock location, not only fits better i think but i can have full suspension travel at any height. also if i really wanted to throw something extreme on the car i've got room to work with a fat tire on a smaller rim much like the first pic i posted which was a 15x10 rim setup.
Car: 1982 Trans Am
Engine: LG4
Transmission: 200C
Axle/Gears: 3:73
1 Post
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
15" Cragar S/S wheels (15x8 and 15x10), drop the nose 2", leave the rear height stock, get some white lettered tires like Radial T/As or something, and a REALLY hairy sounding exhaust system.
Car: 79 Ford Mustang
Engine: 306
Transmission: t5
I dont think the rake look is that good looking when the car has ground effects. If you had a SC without ground fx and you gave it a rake with some fat tires out back it would look good. Id show you a pic of my mustang with a slight rake look but i dont want to ruin the post by putting an ugly car in it. even though it does have the "badass" look that i think you are going for.
I sure hope you aren't planning on throwing some massive drag tires on the car and doing the rake look, while you still have the 305 in the car......or at least gonna replace it sometime soon....
Car: '87 t-top, '88 'vert
http://f2.pg.briefcase.yahoo.com/bc/...video1&.view=l
http://f2.pg.briefcase.yahoo.com/bc/...85+Z28&.view=l
Car: 1985 Camaro, 1986 Trans Am
Engine: 5.0L carbed and 5.0L TPI
Transmission: TH700R4
Axle/Gears: 3.23 and 3.27 posi
I've always loved 17" Fikse FM5s. :hail:
Oops, how about I attach the pic this time!
Car: 92 caddy PIMP
Engine: 4.8
Transmission: i dunno
:lala:
:lala:
Nate
#42
Flyinlow92rs i dont want to flame or anything but you say some pretty stupid things man. if you read my sig direct quote "Then by late summer LT1 SWAP" im just saying use some common sence before saying something and no its not a falme but dude in other threds and such you just say some stupid things but this isnt an insult dont get all hyped up about it just next time read the thred and sigs and such when posting thanks *edit* i forgot oh and thanks for all the pictures guys its truely helping me
#43
I had to switch to the cragars for a while as one of my C5 rims got bent. I've recently aquired another one ($65 bux!! not bad for a rim!) and put the C5's back on.
#44
heres a pic of my 275/60/15's in back and 235/60/15's in front. Its the best pic I got for now as my driveway and yard are full of cars.
#46
Badass
Found some Badass seatbelts! Nicey nice!!
Please don't upload crap like that here. People view this site from work and don't need that.
#47
Car: 85 firebird
uhm,yeah too bad the pic wont be up for long!
#50
Car: 85 Z28
Engine: 305 TPI (dead) -> building 355
Transmission: 27 spline 700R4 (another one died) -> T5 goin in next
The seatbelts are on a girlfriend of an http://www.coloradof-body.com member. He posted the pic and it spread like wild fire. It's on a number of different sites now.
-Jesse
-Jesse
