Rear hatch glass trim... so who has restored it?!
I see a lot of nice cars here pretty often, but I notice that many of us have not restored the hatch glass trim. Has anyone done this or plan to do this? I sure know I want to... the rusty, peeling black look just doesn't do it for me.
Car: 1987 Iroc-Z28
Transmission: auto
i just sanded the areas where the paint was actually chipping, sanded some minor rust spots smooth, and sprayed w/ duplicolor....took maybe 15 minutes and looks great
Car: 1987 Iroc-Z28
Transmission: auto
no my digi camera isn't working now....i sprayed the entire trim though, not just the problem areas, because you could tell where i had put on the new paint. i just sanded the problem areas, masked it off, and used duplicolor flat black...if i can get my camera working i'll snap a pic
fixed mine years ago when it was the original color. however its starting to rust again so i plan to do it soon. just sand and paint, i did it in my garage; much better then going through the hassle of doing it in a booth. it looks and works just as nice.
i have no real close ups unfortunately...
well I didn't exactly restore mine but I did scrap off all the rust and painted it over in a semi gloss black, looks a bit better than the greyish rusty finish before. I might have a pic and upload it later.
Car: 1999 Z28
Transmission: A4
I am currenty doing this now. I just sanded half of it, and have it smooth. I SHOULD paint it tomorrow, if nothing is going on. Like said above, just sand it, tape off the glass and put newspaper over the quarter panel, and have at it.
It will look better than with the rust.
1 Post
Car: Trans am
i havent had this problem , 55xxx miles and no winters and garage storage has done wonders for the car. But i have to do it with the defrosterless hatch i just picked up . Just sand prime and paint.
Car: 1988 Pontiac Firebird Trans Am Vert
Engine: 5.0L TPI
Transmission: 5-Speed
Axle/Gears: 3.08
haha, that's too funny. Your setup looks vaguely familiar to mine.
Yeah yeah, I know I posted 4 pictures, but I didn't think there would be a huge response for this one so I gave myself permission.
I have more shots of the car if you would like to see them.
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Are you guys just fixing the top, or are you going all the way around the trim, to the bottom? I would think that for a straight-up resto of it, you would need to take the hatch off the car and do it. I'm sure that would be a lot easier in the long run.
IF YOU HAVE 5 PEOPLE TO HELP
Car: '86 T/A
Engine: 350/LT1 Intake
Transmission: 700R4 - Built
Axle/Gears: 4th gen 3.42
I've done it. It makes a big difference too. Just sand it down a little bit, clean it. I used flat black model paint to paint it. I put it on with a brush.
Looks good over 2 years later.
Engine: 5.0L TPI
Axle/Gears: 3.08
But doesn't the trim go all the way around to the underside of the glass? Are you painting that part too? This is what TZF is saying about taking the hatch off... it'd be a bitch to paint the underside with the hatch open. You'd have to mask the whole rear interior too.
yes it does a little bit, but I didn't have any rust under there and it looked good enough to me not to do anything to it. I also put a coat of clear on top of the paint. So far so good, no rust returned.
that's the first thing i did when i got the car. here's a little variation from the other replies though....for the paint...they sell spray cans of "black trim paint" at automotive stores, but what i found to have a better (more stock-like, longer lasting) finish is the spray paint made for BBQ grills. seriously. i've used it on wiper arms and the antennae as well. like a charm.
evan.
evan.
Engine: 5.0L TPI
Axle/Gears: 3.08
Originally posted by Gumby
So where is the final pic with all the paper off???
Anyone ever do or think of doing a contrast color?
and, no not really.
P.S. I know... I hate the downpipe too, hopefully I will be getting rid of it soon.
Car: 1987 IROC-Z
Engine: 305 tpi
anyone replaced or restored the 4 bolts that hold the hatch on the hinge? i am missing one of the covers on one of them and it's all rusted up. any ideas on how to fix this?
Car: 91 camaro rs
Hatch off-took 2 of us and a clothes prop to hold it open while we got our fingers underneath! Then bare metalled both sides, followed by etch primer and satin black. Looks sexy!
Car: 1984 camaro
Engine: 60*V6
Transmission: 5spd
Car: 1994 Trans Am
Engine: 5.7L LT1
Transmission: 6-speed
I just got through painting the hatch trim yesterday. I found it easier to remove the hatch than to mask off the rest of the car. That also allowed me to get the sides of the trim rather than just the top. I went with semi-gloss black but I imagine flat black would have looked much better. Honestly if I had to do it all over again, I would just rip that blasted trim off. My 94 T/A doesn't have it and looks just fine
Car: 1992 GTA
Axle/Gears: 4.10
When I installed my 4th gen wing on my GTA I removed my back window and actually painted certian parts of the glass black before tinting it. The top of the hatch glass is hard to tint perfectly so that was painted, as well the grid lines for the left and right side of the defrost were painted on the sides of the window to make the job look very clean. While I had it off, I sanded down the moldings, applied an etching primer and hit them with a high gloss black. If you are still curious I can post a few pics. I just need to go grab my digicam and shoot a few pics.
Car: 91RS
Engine: 305tbi
I just sanded, primed and painted. I used the Dupli (spelling?) paint that is supposed to match the car, it doesn't match but the trim isn't supposed to match. Actually it might if I used there clear. I think it looks pretty decent, definatly a huge improvement from the rust.
My car is black BTW.
Car: 88 Iroc 91 Z28
Engine: 5.0 LB9
Transmission: WC T5 / 700R4
Axle/Gears: 10 bolt 3.73
I did mine when i painted the car.I took i off the glass and cleaned it up with a scotch bright pad on a die grinder.
Then pinted it with sem trim black looks like new now.
Car: 1992 GTA
Axle/Gears: 4.10
Okay I just clicked off a few pics. They came out kinda dark as the car was in my shop. The car is a dusty mess because yesterday I just dropped my tank and installed my Walbro pump so bear with me
Tomorow when I pull it outside I can take some better ones if these don't do the tick. Its kinda hard to see the gloss black shine, but it looks very good compared to just the factory flat black.
http://www.villagephotos.com/pubbrow...elected=868329
EDIT: I just looked at the pics, they really don't show the trim that well. I will take some more tomorrow with the car outside.
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
I still wonder if a contrast color would look nice.
silver or whit. get the piece chromed , golded or powder coated.
a blue car with white stripes could do all the trime in white.
black with yellow strips the same
green with purple stripes the same
Street Lethal
04-30-2019 12:14 PM
