Hoiw do you polish?
1 Post
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Uhmm check out the sticky post at the top of the page. Sand down with 120 grit paper then do 320 wet 400 wet, followed by emery, tripoli, and white rouge compounds with a buffing wheel
Car: 1989 Firebird
Engine: 5.7 LS1
you will need a drill that turns 2500 rpms, but yes you can get buffs for the drill. Tripoli and white roughe are fine and really fine aluminium polish. Check out eastwood-co.com I think it is eastwood, they have two kits, one comes with grinding compund 80/220/320 and tripoli and white roughe, the other is just the tripoli and white rouge, both come with buffs. its like $80/$30 for the kits.
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
Check out the sticky I made at the top of this forum. It has links to threads that cover everything you need to know.
Good luck
Good luck
bigjay89gta
10-15-2015 08:04 AM
