ROH 17x9 Snyper wheels
Car: 1984 Pontiac Trans Am WS6
Engine: H.O. 305 5.0L;L69
Transmission: T-5; Axle Ratio 3.73
First off, for you guys running the ROH 17x9 Snyper wheels with a 1-1.5in drop....are you guys rubbing at all?
Second, where did you guys get your wheel from? The cheapest I have found was $179 for 17x9.
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
I have ROH ZS wheels that are 17 x 8.5 but no drop on the suspension so I can't answer the rubbing question but I do know where to look for the wheels. Try JDwheels.com. They can probably answer you question about rubbing too. Very knowledgeable about our cars and very helpful.
One more thing to try is a search. There are a lot of guys on these boards running Snypers and that's how I did a lot of my research. The one name that I can think of off the top of my head is ShiftyCapone. Try a search of some of his posts.
Car: '88 Iroc
Axle/Gears: 3.45
Try these guys too. They're the actual importers. They have an outlet in Arizona and one in NewYork. Prices appear to be similar. Shipping may make the difference, especially if you can pick them up.
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: Base Firebird
Engine: TPI 350
Axle/Gears: D44
i believe they do... people have put s10 wheels on thirdgens, and i've seen thirdgen iroc wheels on s10's.... i think it may be only 2wd s10's, though......
Yea ask Shifty. I know he's got 275s in the back and 245s in front and doesnt rub with the sportline's which is a 2" drop.
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
bump, i just got off the phone with jdwheels and they said modification MAY be required if i want 17x9 in the front. im running the eibach pro kit, so that prolly doesnt help any. prices i got were
179 each wheel
25 hardware (lugs, socket, valve stems)
50 shipping
anybody offer any insight wether or not 17x9 will work? planning on a 275/40 tire
179 each wheel
50 shipping
ahhh...so I am not the only one they told that too...I know they told me that it will rub on some cars and on others it won't. So I should go with 17x8 to make sure no rubbing will happen.
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
17x9's on all fours with 275/40 in rear and 245/45 up front. No rubbing at all with Eibach Sportlines drop(1.5" front, 2" rear). I got my wheels from a local wheel/performance shop. They make 3rd gen specific snypers so you don't have to worry a whole bunch about measuring.
Location: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
1 Post
Car: 1991 Trans Am
Engine: LQ4
Axle/Gears: 3.70
the thing is, i would like to be able to rotate the tires since it seems like my back ones wear alot faster for some reason
, so i want the same tire all around too
![Stick Out Tongue](https://www.thirdgen.org/forums/images/smilies/tongue.gif)
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Originally posted by Kj Rockz
You mean you dont have to use spacers, if that is the case, how can I get a hold of them. Cause I would like to order some, and about how much do they cost?
Originally posted by KagA152
the thing is, i would like to be able to rotate the tires since it seems like my back ones wear alot faster for some reason , so i want the same tire all around too
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
still better then not at all imo
What difference would it make if you ran all 17x9 or rear 17x9 and front 17x8...better handling?
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
drptop70ss
10-04-2015 09:44 PM
