Black Paint
Car: Right now 93 Lumina
Engine: 3.4 DOHC
Transmission: 4T60-E
Black Paint
does anyone have a recomendation on what brand paint i should use to paint my car? also is there such a thing as Candy black? also what exactly is Candy?? oh and can Por-15 be used as a primer??
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Read up on POR-15...
do a search on google I think it's www.por-15.com and that will answer those questions....
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my car is ppg 1683 black base coat. it is pretty much the purest form of black that you can get.
Engine: 3.4 DOHC
i like the color on the black cadillacs (escalade) what number is that also ppg 1683 is there a site i can get that?? (paint is expensive)
Car: 84 camaro Z28
Engine: 434sbc
you should be able to go to any local automotive paint supply store and the should have color chips that you can look at. 1683 is not really that expensive.
Car: 84 camaro Z28
Engine: 434sbc
you could probably get away with about a half gallon. i will look into that for you. i'll find out how much i used on my car.
For a daily driving 15 year old car, ICI ValuPro was good enough for me.....Basecoat/Clearcoat....it shines just like all the other base/clear systems out there...and is MUCH MUCH cheaper.....plus you can have the paint pre-mixed and shipped to your door... for my artic white it was 66 for a unreduced gallon....plus 30.20 for a gallon of reducer, i now have 2 sparyable gallons of paint for $96. plus they have an entire system for it, etch primer, epoxy primer(i used this for durability), high build primer surfacer, primer-seals, plastic primer. you have to do some reseach and contact ICI which is owned by PPG now, so call PPG and they can hook you up with a local retailer of the stuff so you can order all the parts that are not listed on the webpage i am about to give you, like flex agent(HIGH recomended for our bumper covers).
http://www.autobodysupply.net/iciautocolor/valupro.htm
It is good paint, i was very impressed buy the quality and price....i have heard rumors that it is the same line as PPGs Omni.
colton_carlson
03-08-2019 12:21 PM
Dyno Don
17
11-02-2015 11:43 PM
hectre13
09-08-2015 03:38 PM
