How do you remove scratches from glass???
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Just wondering if anyone knows how to get scratches out of glass. My side windows are scratched up from my old cracked window sweeps. I replaced the sweeps and would like to tint the windows, anyone have any idea how I could get these scratches removed. They are on the outside, so it wouldn't stop me from tinting the windows, but I think they would show up bad. Thanks in advance Jason
Car: 84 Z28
Engine: 355
Thanks, I knew I had saw a post on it before. Could you give me the exact instructions so I don't mess anything up. Thanks again Jason
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Originally posted by si_camaro
Mild cutting polish, like T-Cut, will do the trick. Just polish it like it was the bodywork. It's worked for me many times.
Car: 85 Z28
Engine: LG4 modified
Originally posted by Sitting Bull
Yes, but what about the deep scratches like one finds on the door glass where it has been rubbing on something inside the door? You know, the ones that are a couple of inches wide?
Oh, and good luck!
Car: 85 Z28
Originally posted by SIMON HOLTBY
You need to get hold or some cerium oxide and a polishing wheel. Nothing else works.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
btw, noone mentioned this so i'll add it..
if you stay in the same place and dont move around the whole glass area, you distort the view.....
T cut will remove a mark that is on the surface of the glass. If the glass is scratched you need 1500 wet and dry paper to flat the scratch and cerium oxide to polish the glass. There is some distortion afterwards as the glass is dished in. I spent a lot of time removing a scratch that a wiper made to the windscreen using various things such as Tcut, valve gringing paste, toothpaste!, jif and nothing really worked except cerium oxide which is what glass manufacturers use to polish glass.
The only real fix is to replace the glass if it has deep scratches.
Simon
Simon
Car: 85 Z28
....and you are in danger of distorting your vision through the glass by taking many layers off
Car: 85 Z28
Simon
Simon
Car: 91 Camaro Vert
I believe I said something like....
...in my second post. Are my messages not being posted or something ??
you implied that you had to move over a larger area of the glass.
i said it.
morrow
01-13-2024 12:29 PM
