18" rims on 89' camaro RS
Car: 89 camaro RS
Engine: soon to be juiced built 357
Transmission: turbo 350
would these rims fit under a stock camaro's wheel wells http://artire.com/shop/BOSS_WheelsBOSS_18x9.html they are kick butt rims.
1 Post
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
i dont think you will have any probs getting those to fit..i have 18s on my iroc and ive dumped it 4 inches in the back and 3.5 in the front..
iroc2nv
iroc2nv
link isn't working....
it isn't the 18" wheel that makes the difference it's the width and the tire size.
you could probably work a 9" without real modifications if you used the stock tire height and definately if you went smaller.
9.5's on the other hand won't work with a real low car unless you do some work. (this is 2" or lower suggestions) a pro-kit really isn't lowering the car so you would be fine.
good luck.
good luck.
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
it doesn't list a specific offset or backspacing for that rim, only that it's positive offset, which won't fit on a thirdgen without a spacer (the expensive variety)
about as far as you can go on a 9" wide rim is 0 offset, and even that you might need a slip fit spacer to get an extra tenth of an inch or two clearance.
Zachattack0925
08-12-2015 09:54 PM
Zachattack0925
08-12-2015 09:52 PM
