lets c some pics of yours!
could everyone who has a pic of the back of there car so u could see the tires and how wide they r post it i want to see what size i should in thickness.
Car: 1991 Camaro RS
Engine: 305 TBI
ha this ised to be my buddys car (let girlfriend drive it and wrecked it) but he got these wheels for free when he needed a set and put them on there, all i know is that they were on 15 inch wheels, and they were 275/60/r15(i think) coopers cobras. they were HUGE!! lol
Car: 1987 "1991 Z" Sport Coupe
Engine: LG4
Transmission: TH700R4
ok since this is about tires....how do u read the numbers? all i know is the last number is the size of the rim
275/40/17 means the tire is 275mm wide and the sidewall is 40% of the width and "17" is... you guessed it the rim size.
285/35/18 means the tire is 285mm wide and the sidewall is 35% of the width on an 18" rim.
And do you know what? All three of these sizes have an identical height. Some are wider with a smaller aspect ratio (profile) and some are thinner with a larger aspect ratio.
Here's two of them 245/50/16 & 285/35/18
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Reading tires,
215/65R15
215--- width of the tire in mm, so its 21.5cm
65-- means 215X65% (215X.65) is the height of the tire from the rim to to top of it.
R-- Radial tire,
15 Rims size in inches
215/65R15
R-- Radial tire,
Car: Check The Sig
hell yea!!! 215's baby! BFG Comp T/A's HR4s... very good snow and wet traction.. but just enuff to where if you hit it, your gunna lose a littin in the a$$
Originally posted by Firebird355
hey ss3933 how do those supertraps sound??
in school for some reason i had a teacher telling me that the wider the tire the worse the traction. i argued that wider is better other wise why wouldnt drag car use skinier ones. whos right here? Sorry about being off topic but its not totally off
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Originally posted by SS3933
Take 245/50/16 for example: The width of the tire is 245mm. "50" is the aspect ratio i.e.(% of width of tire), sidewall thickness measured from the edge of the rim to the corner of the tire. In this case "50" means that the sidewall is 50% of 245mm which means it's about 122.5mm of sidewall from the edge of the rim to the edge/corner of the tire. "16" of course is the rim size.
Thank you! THat has always bugged me!
Engine: LG4
console on the paint?
does anyone have the same tires as me 215/60/16? if so do ur fronts rub the well towards the back of the car?
Engine: LG4
Originally posted by Zepher
Here ya go,
4th gen rear with ARE 16x8 3rd gen wheels on my friends car.
Here ya go,
#45
Car: 1989 White Trans-AM
Engine: 305 TPI hopefully Upgraded Soon.
Transmission: Crappy Needs Improvment.
hey how do the yoko's handle? and how much were they for all 4?
#46
Car: 02 ws-6
Engine: 5.7 liter
Transmission: t56
im running 255 in the front. Im running the yokohamas avs db series and they're awsome. We resently had a rain storm over here at the bay and they were bada** in the rain. I rarly hydroplaned on the highway. The traction is incredable. I got the front tires for 161 each and for the rear tires 171 each, so the total of 778.78. It's alittle pricey but for a quality tire I highly recommend them.
#49
Car: 00 T/A Firehawk
Engine: 346ci LS1
Transmission: MN6
Axle/Gears: 3.42 LSD
Originally posted by SLP IROC-Z
245 50 16 Toyo Proxes Fz4-great tires id recommend em!
