Cowl Hood
Car: 1986 Iroc
Engine: 5.3
Transmission: 4L80E
Axle/Gears: 9 Inch w/ 3.55
Cowl Hood
I was just woundering what companies are out there that make cowl hoods for camaros. I still cant decid if I want to go 4 inch or 3 inch. If any one has pics of both that would be great
1 Post
Car: 1987 Camaro Z28
Engine: 335 TPI Stroker
Transmission: Tremec TKO 500
Axle/Gears: 10 bolt / 3.42
I bought my fiberglass hood from Atlantic Coast Customs. The Hardwood cowl is very similar to mine. It fits pretty good, I just need to do a little adjusting. Sorry for the crappy pics
It's a 4" cowl by the way...
Car: 1988 Trans Am GTA
Engine: 5.7 TPI (Now HSR)
Transmission: 700R4 by Probuilt
Axle/Gears: 3:27 9 Bolt Posi W/ Discs
well Id say that the first pic you posted looks a little smaller than a four inch cowl. I would say go with three inch because to me it looks cleaner than a four inch unless you have something serious under there.
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
This is a Harwood 3" cowl. I will say it took a little getting used to the blocked vision of the cowl vurses the flat hood but I would not trade it cause it looks way cooler.
Car: 84 Z28
Engine: 355
Transmission: 700R4 with corvette servo
Car: 87 IROC Z-28
Thanks for the comments. I am running a TPIS Miniram and a air cleaner that I fabricated. I glassed in the underside of the hood to make the cowl functional. No problem with clearance at all.
Check out the link below for details and pics.
https://www.thirdgen.org/rides/index...ew&rideid=9388
Car: 1987 GTA
Transmission: 4L60e
406-Z, that's a very clean car you have there. Being you're in NW Houston, pay attention to the SWMG portion of the thirdgen.org forums. We've had 2 very successful Houston Gatherings....and the next one should be even better. End of summer most likely.
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
i dont have a good pic but this is a harwood 2.5" scoop that was grafted on
sorry for the bad pic
Maybe you guys wouldn't know this, but I want to ask anyway. What is the tallest single plane intake manifold that will fit under one of those 3" Cervini's? (ex. Victor Jr, Victor, Super Victor)
91TTOPZ
Exterior Parts for Sale
09-20-2016 12:42 PM
