How do you polish curvy aluminum surfaces?
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
I have seen a lot of companies offer polished products like intake manifold and other aluminum things that have many curves and crevices. I have even seen a very cool polished stock TPI manifold.
My question is how in the world do they smooth out and polish all theses little groves? I was thinking about polishing my PBR aluminum brake calipers
you'd have to do a search on it, i know they use like 200grit, then 400 grit, then 600 grit and then some polishing compound like black magic from there on...the exact recipe is on here somewhere
1 Post
Car: 1989 Iroc-Z
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
You could fold a piece of sandpaper and stick it inbetween the fins. Its definitely not easy to do, no matter what you use.
1 Post
Car: 1989 Iroc-Z
How do companies like Holley or edelbrock do it? Is there a special machine or something. Like take a look at the carburetor below. There is no way you could get in all those small groves with sand paper.
1 Post
Car: 1989 Iroc-Z
And here is a polished edelbrock performer intake. I don’t see any ways of doing this with sand paper.
1 Post
Car: 1992 RS
Engine: 406 Stealth Ram
They probably use a vibrating media polisher. Its just a big bucket of vibrating material that slowly takes away the surface, just like sandpaper would, only it envelops the entire part. They probably put plugs into all the ports then just toss it in there
Here's some more info on it if you're interested: http://www.royson.com/whatis.html
Car: Check The Sig
exactly... there are HUGE bins that they throw the metal pieces in. They varry from bin to bin with whats inside it and what grid the material is. My dad used to have one for his gun, but was only for the gun shells, not the gun itself. It wouldnt be big enuff to fit a plenum, but maybe some bolts.
Car: 85 Camaro SC
Engine: V6
I use a die grinder with sanding drums "120,400" grits. I use strait drums ranging form 3/8 to 1/2 in dia. And also 3/8 tapered sanding drums. I would go insane if i'd try to sand all that by hand.
Car: 89 WS6 Formula
Engine: 305 TPI w/ some mods done
Transmission: Modified THM700R4
Ive been to the holley factory. The have a big bowl type bucket which they stick the parts into. The bucket contains small chrome particles which when heated melts onto the surface of the part. Its pretty cool when you see how its done.
bigjay89gta
10-15-2015 08:04 AM
