Now this is a Cold Air Intake
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Put the headers on, installed the Hurst shifter, and other small things today.
![](http://www.transamws6.com/pics/04-2003/air_intake1.jpg)
![](http://www.transamws6.com/pics/04-2003/air_intake2.jpg)
![](http://www.transamws6.com/pics/04-2003/air_intake3.jpg)
![](http://www.transamws6.com/pics/04-2003/air_intake4.jpg)
More pics of todays work here,
Car: 92 RS 25th Anniversary
Engine: 350 L98 w/Vortec Heads
Transmission: 700 R4
Engine compartments frustrate me because the only way to keep them looking good is to not drive the car!!!
![Mad](https://www.thirdgen.org/forums/images/smilies/mad.gif)
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
What freakin size is that?? My gosh!!!!!!!!!!! Where does the other end come out at??
Polished is my vote!!!
Originally posted by Trans Am#5
Not using a MAF?
Not using a MAF?
![Big Grin](https://www.thirdgen.org/forums/images/smilies/biggrin.gif)
I need to head to bed. Julian wants to come over early and finish up his Trans Am. His car needs a fuel filter and it's ready to roll.
1 Post
Car: 1986 IROC-Z
How would you go about cleaning an engine compartment weakly? Degreaser or just car soap and water?
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Zepher..I want one..where'd you get that??? And yes Polish it!
samdog1232000...just use soap and water. to do the engine bay, but you shouldn't have to do it weekly, well unless you drive aloit of stone roads, and in the rain???
Car: 1985 Camaro Z28/1989 Pontiac Trans Am GTA
Engine: 305 tpi/350tpi
Zepher I thought you were putting a 6-speed in? Isn't the hurst for an automatic?
It's aluminum and it is huge in person. It is from a mack truck, just have no idea which one and what year. I traded a rear end for it with a friend of mine who had it on his 90 Formula 350.
I am putting in a 6 speed.....eventually. I'll live with the auto for awhile.
Car: Kitt
Engine: Classified
Axle/Gears: Moser/4:11
Dude..that's bad ***!! If it were me, I'd run it all the way under the car and kinda make a ram air cold air package. Looks sweet dude!!!
Car: '88 T/A and '90 T/A
Engine: LB9/383
Transmission: T5/700R4
![Wink](https://www.thirdgen.org/forums/images/smilies/wink.gif)
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
zepher- what kinda headers you running on the LT4 heads?
just regular headers meant for a L98 3rd gen?
i ask because i might be getting some LT1 heads soon.............
(LT1&4 heads have D-shaped exhaust ports)
![](http://www.transamws6.com/pics/wreck/02.jpg)
Spun out on the highway at 75mph and slid nose first into a guard rail, then spun around and tapped the rear on the guard rail and finished the 360 and pulled over to the side of the road.
![Frown](https://www.thirdgen.org/forums/images/smilies/frown.gif)
I am running the Hedman 68460 long tube headers. Not sure if they are the best for this application, but they look cool and were really easy to put on from underneath the car.
![](http://www.transamws6.com/pics/04-2003/headers.jpg)
I probably should have kept this setup,
![](http://www.transamws6.com/pics/transam/engine.jpg)
But I was going to run MAF on the LT1 since I didn't know you can turn it off in the 94-97 cars. I love the dual cold air look.
I love the SLP dual cold air intake. I will be running it on my lt1 set-up!:hail:
1 Post
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
Originally posted by Zepher
Thanks.
I need to paint that air tube. should I go red or black, or should I polish it?
Thanks.
Originally posted by Trans_AM_88
more info on the mack truck intake!
i want one
i read the topic and was expecting the intake in a refridgerator, hence "now this is a cold air intake" lol
but that looks awesome man, good luck on getting the rest together!
1 Post
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
Spray painted headers.... That’s going to peel off.
But nice intake, definitely polish it
#42
![](http://www.transamws6.com/pics/transam/Edelbrock.jpg)
#43
Is it safe to steam clean an engine comparement as long as you cover the distributor and other electrical parts. My engine compartment is pretty dirty. I havent cleaned it since I bought the car!
#45
1 Post
Car: 1989 Iroc-Z
I am not too worried about the headers. I used the same paint on my manifolds a few years ago and it never peeled off,
#47
Wow what spraypaint did you use? I used the 1200 degree stuff from autozone and it's peeling a lot.
1992 Trans Am
05-10-2023 07:19 PM
Brinkkl2000
08-04-2018 08:29 AM
