would these 18" adr rims fit?
Car: 87 vert
would they fit our 3rd gens w/o adaptors?
http://cgi.ebay.com/ebaymotors/ws/eB...&category=6782
let me know. i see that is 5x4.75(120mm) but the offest is +38.
any info would be great. i seen this post about using bmw rims:
https://www.thirdgen.org/techbb2/sho...&highlight=bmw
but what does the offest have to do with anything.
Car: 87 vert
True. i figured that but then read the post:
https://www.thirdgen.org/techbb2/sho...0&highlight=bmw
and was confused and was wondering.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i am a little confused, what does a fitment for a 4thgen have to do with fitting BMW wheels?
the wheels you posted (ebay) are a 4thgen wheel. they will need a spacer.
if you can find the exact same wheel for a BMW fitment, then it should fit without an adaptor.
Car: 1987 iroc-z custom
Engine: 355 tuned port
Transmission: 5spd baby, only way to go
Axle/Gears: 3.45
thirdgens have a bolt pattern of 5x4 3/4 or 5x120.7..
bmws are 5x120
.7 doesnt do anything...
the offset simply means where the bolts holes are positioned from the middle of the rim itself..
+40mm is 40 mm forward (newer cams/firebirds)
-40mm is 40 mm behind the middle of the wheel...
so..you should be ok if you get a +40mm (back) and max of +18mm for the front
hope this helps
iroc2nv
bmws are 5x120
hope this helps
iroc2nv
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
howdy. those are nice lookin rims. they have that modern look while retaining that cutting edge look.
by the way, i paosted in another thread but dont know if you read it but here it is again
"hey mario,
how did the 145 speedo install go? did my custom made "tool" help you pull the needle off?
that was the last part i sold off the car as i am fixing it. you wouldnt be will ing to sell it back to me would you i pay shipping?
thanks
anthony
"hey mario,
thanks
anthony
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Hey, does anyone actually know the answer to this question, ive been looking for rims too and there are a whole lot more that say they will fit on 4th gens and not 3rd gens. You just need spacers for the front, but what size do I need. im thinking about eagle 211 series or maybee some newer C5 repros in 18in. Anyone know?
Car: 88 IROC Convertible
Transmission: Raptor 700
well if you read the posts this question has been answered a few times in this thread alone. Those are 4th gen wheels, you will need spacers for the front and back unless you plan on running a 4th gen rear, then you will only need the spacers for the front. look at iroc2nv's post, he tells you what size you need
Car: 1991 Camaro RS Vert
Engine: 305 (L03)
Transmission: 700 R4
nikh...
I just got done doing my rims and tires, they are replica 2000 C5 wheels 18 x 9.5 wrapped in Kuhmo 712's 275 35 18, I think they look sweet, I will have pics in the next couple of days.
Car: 1990 Trans Am GTA
Engine: 5.7 TPI 350 sd
Transmission: A4
Zenetti Vega 18x8.5 offset 20 www.superbuytires.com
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Dooski,
did you use spacer's between rim and hub,and if you did,how thick are they.I'm planning to put spacers between my rim and hub because rim is so cloce to steering linkages(17x8,5 et13 wheels front and rear)
Jari
Jari
Street Lethal
04-30-2019 12:14 PM
Djmathis123
09-29-2015 01:36 AM
