What type of steel wool to clean windshield?
Car: '87 Z
Engine: 355 in the works
I remember seeing it on TV, forget what show, but it was a detailing tip. It was a really really fine steel wool, and you cleaned your windshield with it. I forget if you used windex and then wiped with the wool, I think it was like that... but anyway, what kind of steel wool was it, 00 or something? Does anyone know what I'm talking about at all??? lol
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Re: What type of steel wool to clean windshield?
I got the tip from a friend of mine who detailed cars proffesionally for 5 yrs. At first I thought he was crazy But after I did it, I was glad I did.
Just make sure you keep the pad soapy (with the soap that comes on it).
use WD40 and a fine grit of steel wool. u can get some at pepboys or any home depot type place but get the finest u can get and use the WD40 and clean the windows and then clean the WD40 off with like windex or something and then wax. it looks great after wards.
Car: 88 Formula 350
Its 000 steel wool.
Invisable Glass by Stoner works good too. Use a newspaper with the cleaner. Use a new piece with each window.
1 Post
Car: 1986 IROC-Z
A friend of mine told me about that tip, as well. I used it on my Jeep and it worked really good. One thing to note, though... my steel wool pad got rusty after I used it a few times, probably because there was a little bit of water on the windshield. Would it still rust if I used WD40?
Car: '87 Z
Dang, it's 000? Reason I asked was my dad got some 00 to clean something, and the 00 reminded me of this, but I wasn't sure if it was the right one or not....
Car: 88 Formula 350
0000 super fine-buff furniture and woodwork to a high luster
using wax or oil
000 extra fine- remove wax or polish from fine furniture
00 very fine- polish & restore aluminum, copper, brass and other
bright metals, wheels, screens and metal lawn
fruniture. remover old finishes from antiques.
0 fine- scour pots, cleans tile grout. removes rust
1 medium- degloss painted surfaces
2 medium coarse- remove paint from molding, etch metal
3 coarse- clean rough metal
4 extra coarse- remove most subborn paint, rust, dirt and varnish
using wax or oil
1 Post
Car: 91 Camaro RS Update: Sold Camaro, now own a "91" Corvette.
Engine: Corvette L98 TPI
Use 0000 steel wool only on older glass because older glass already has minor scratches and swirls in it. Never use it on a new windshield because it will leave very fine swirl marks in the new glass surface. Also, remember to always wash the vehicle after using steel wool because the steel particles will turn into rust if left on the painted surface.
Bohemian
08-15-2017 05:11 PM
Saxondale
Exterior Parts Wanted
09-07-2015 06:11 PM
Saxondale
Exterior Parts for Sale
09-07-2015 11:40 AM
