Att KandiedZ: Re BBS style rims...
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
I believe you showed a picture of these rims a while ago and I was on another forum and someone has the exact same rims you were talking about up for sale, so I got the info on them. I believe it was you...
I have a set of 17" 5Zigen Heidfeld rims mounted on 205/40/17 Ventus tires with 90% tread left. Bolt pattern is 4x100, not sure of offset but they came off my integra. There is a scratch on one rims with a bit of clear coat damage on the lip. Asking 1200 canadian obo.
Re: Att KandiedZ: Re BBS style rims...
And, they're also 4 bolt wheels, so you're going to need adapters.
Maybe try to find proper sized wheels in that style.
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Re: Att KandiedZ: Re BBS style rims...
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Re: Re: Re: Att KandiedZ: Re BBS style rims...
Originally posted by Brett Gutshall
Do you not read?
Do you not read?
Brian
Re: Re: Re: Re: Re: Att KandiedZ: Re BBS style rims...
Originally posted by 89blackGTA
Interesting, both of us seem to be asses.
Brian
Brian
1 Post
Car: 89 Black GTA
Engine: 5.7 TPI
Re: Re: Re: Re: Re: Re: Att KandiedZ: Re BBS style rims...
lol. I'm sorry man, I just couldnt resist.
Brian
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
you should be able to find that style in a BMW rim, then you can get 17 or 18's that BOLT ON, and are wide enough.
The BMW fitment are you talking about is from a 95 and up BMW 5 and 7 series that has 13mm offset with a 120mm bolt circle. Be careful, because our bolt circle is 120.65, which means those rims will be a very tight fit. It may be difficult to get the rims on and off.
actually the rims are available in both 5 bolt and 4 bolt, perhaps different offsets too, but 5zigen makes them.
