just put my 408 in
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
just put my 408 in
well, today my dad and i dropped the 408 in. i can't wait untill i get to start it. let me know what you think
Car: 87' Firebird
Engine: 2.8L
Transmission: Standard
uhhh ... ya remember, we bet on that one thing and i won your car... so ill be expecting the car in my driveway within the week
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
Are you actually going to keep that carb? I would definitely get a holley 750 or something..... And the EGR...that definitely has to go...
heavy_chevy29, i've got a question for you 1... are you going to use the carb that's on there now or are you upgrading., #2 if you are going to use that cc-qjet on there, what are you plans for the computer and sensors?
just curious seeing that computer-controlled carb on there, nice motor, the big cubes, brad
Car: 84 camaro Z28
Engine: 434sbc
thanks for all the complaments.
here are some specs:
1971 400 sb bored .040 over= 408
heads are the stock 441 castings (for right now because i need to keep some of my money)
Edelbrock performer intake w/ Q-jet carb(for right now)
hooker #2055 headers w/ Jet Hot coating
the cam is:
int lif@valve= .442 in
exh lift@valve= 465 in
the guy who helped me build the motor ran this setup on desktop Dyno2000. the hp was 308. the torque is 442 lb ft.
i plan on using the stock carb for the break in. once i get the money, i plan on getting a 750, maybe.
as for that bet that was mentioned, i don't recall making a bet with you.
the cam is:
Car: 84 camaro Z28
Engine: 434sbc
once i get it started and broken in, then i have to bring to a shop and get my SFCs installed as well as a stainless steel flowmaster ehaust. this spring/summer i'm going to run it at E-town and i'll post the results.
Car: 1978 Chevrolet C10
Transmission: Turbo 350
thats one badass engine setup, BUT if you ever have an oil leak your screwed, black oil, black engine, oh well i have that problem, sweet setup though and good luck.
hey Heavy when u go to e-town to run during the spring/summer time and i hope to have my car finished with what i have planned we should met down there.
Car: '91 Camaro RS
Engine: TBI 305... bah
Transmission: Slushbox 700r4
very awesome! kinda reminds of the saying "there's no replacement for displacement!" heh heh, lets see some of thoes v-tech boys keep up with that beast!
doc
doc
Originally posted by Jim85IROC
a 400 .040 over? I thought that it wasn't recommended to do more than a .030 overbore on a 400 block?
Car: 1984 Camaro Z28
Engine: 350 CID
Transmission: Beefed up 700R4
yea maybe me, you,1982chevycamaroz28(tim),SSZ28, and whoever else can meet at e-town once my car is finished...it would be awesome to have a bunch of thirdgens down there all at once
Originally posted by fast83camaro
I think the siamesed bores keep it safe.....
With most other small blocks, you can safely do a .060 overbore, but I was always under the impression that on 400s you couldn't do more than .030 due to a possible deformation of the siamesed bore from the heat.
Car: 84 camaro Z28
Engine: 434sbc
.040 is about a 50/50 chance of having a proble. .060 is when you are most likely going to have a problem.
as for etown. i have no idea when im going. i will let you guys know when i go.
ambainb
04-25-2016 09:21 PM
