17x11's up FRONT ??
17x11's up FRONT ??
I've read the posts about 17x9.5's up front with Skulte's adapters..but I can't find anyone that has put 17x11 (ZR1 wheels) up front.... I want to do this for autocross/road racing.
Does anyone here (or know anyone) that has ever put 17x11's up front ? If I have to do some MINOR fender well snippage in places that aren't too visible on the exterior, that is fine, as long as it is not drastic. My car is a 1LE and I do not plan to lower it.
If you've put 17x11 up front - what size wheel adapter did you use ? I'll assume you used the GS 50mm offset 17x11 wheels??
Any info, lemme know!
- Dean!
- Dean!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I don't think you'll be able to turn very sharp with them on a thirdgen.
I have problems with my wheels rubbing both the front and rear inner fender wells with my 17x9.5 and the 335/35/17's I tried to put on my rear where so much larger than my 17x9.5 OZ's with 275/40/17, it would be a very tight fit.
Maybe I could try it one day, have my friend bring them over again and put them on the fronts.
1Aauto
Sponsored Vendors
08-26-2015 02:18 PM
ProtoMaster22
08-26-2015 07:50 AM
