Detailing the underside of your car
Car: 1983 Camaro "SC-350"
Engine: Mild 350 4-bolt
Transmission: 700R4 w/ TCI Stall
I plan on pressure washing the underside of my car, and painting it all black. So my question is, who has done this or something like it? (ie painting, undercoating, etc) Would like to see your results. Pics are very welcome!
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
I wiped down the old undercoat I had on there with thinner to clean the dirt off and used Duplicolor truck bed liner on mine.
I still have to clean & repaint the rear, tq arm & drive shaft plus a few other misc things.
Here's the only pic I have of underside...
Car: 1989 IROC-Z
Engine: 383 stroker
Axle/Gears: Moser 9", 4.11:1
I have yet to undercoat it, but I plan to clean it and put POR-15 on it in the spring. Go to www.por15.com for more info. I ordered two of their starter kits for about $30 I think and I'm going to use it on my underbody and wheel wells to prevent rust.
Wow, deadbird, how did you get that dual exhaust? Thats sweet! What kinda mufflers you running? If you have any more pics please post em!
Matt
Matt
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
yes deadbird please post.... any problems with scraping?
1 Post
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
I will have to throw up some pics on Monday. I don't have my disk with the good shots. I cleaned the underside and shot it with Duplicolor sound Eliminator and undercoating. So now it is black with red suspension pieces and gas tank. Soon we are going to replace the rear end with a disk rear with 373 gears. It will be red along with the Soon to get aluminum(next 2 weeks, I hope)drive shaft, torque arm and transmission (gonna put a shift kit in anyway, so while its out!)
If you do undercoat it I recomend painting back over it. My undercoating was messy to deal with, esp when changing the fuel filter!
By the way that exhaust looks awesome!
Engine: TPI 305/ v6
1 Post
Ok here you go. Be prepared for some road grime. Now the car had not been detailed in this shot. I was getting the subframes installed and decided to shoot some pics. At the TA nats I got under the car while it was on the trailer and touched up stuff I could not reach before. It was scrubbed and repainted. So in other words it looks better now then in these shots.
Driveshaft looks nasty!
1 Post
Here is up front. Man you can tell on the passenger side I had an issue with the coolant. The return hose to the radiator coolant reservoir got nicked at a show in fl and sprayed the bay down. When I go with an LT1, I'm going to a tubular crossmember. Yes it will be red...
colton_carlson
03-08-2019 12:21 PM
Linson
08-21-2015 02:12 PM
